Thread: P0300 Code. Random Misfire NEED HELP!
Results 1 to 17 of 17
  1. #1 P0300 Code. Random Misfire NEED HELP!
    SE Level Member JcGTP39's Avatar
    Jul 2011
    Grand Rapids Michigan
    Okay I'm so stumped on this one guys did everything that I know that could cause this issue. It misses at idle. when you put it in drive you can't feel it cause there's a load on it.
    What I've done
    New Plugs gapped to .60
    New wires
    New Colis
    Up stream O2 sensor is good replaced that 4 months ago
    No Converter
    No Downstream O2
    Tested the the coil Module like 6 times test out good
    Could it be the injectors or possibly a PCM? I just orderd one from zzp for black Friday should get on Wens, tell me what you guys think thank you
  2. #2 Re: P0300 Code. Random Misfire NEED HELP!
    Omaha, NE
    Are your plugs in the right order?
  3. #3 Re: P0300 Code. Random Misfire NEED HELP!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    what mods do you have?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: P0300 Code. Random Misfire NEED HELP!
    Jul 2011
    Yes wires are on the right plugs. Tripled checked them lol.
    And my car is stock besides a CAI
  5. #5 Re: P0300 Code. Random Misfire NEED HELP!
    Omaha, NE
    What are the new plugs, wires and coils?
    Is the new O2 a splice in?
  6. #6 Re: P0300 Code. Random Misfire NEED HELP!
    Jul 2011
    Plugs are autolite double platinum 104 I had delco ones in it still did the same ones. Wires are NAPA premium and so are the coils and the o2 the OEM one that plugs right in
  7. #7 Re: P0300 Code. Random Misfire NEED HELP!
    Omaha, NE
    With just a cold air, you shouldn't be running 104s. Switch them out with stock temp plugs and your issue should go away.
  8. #8 Re: P0300 Code. Random Misfire NEED HELP!
    Jul 2011
    Same thing*
  9. #9 Re: P0300 Code. Random Misfire NEED HELP!
    Jul 2011
    I did. I had AC delco's in it that had like 5000 miles on them and did the same thing. I got a smaller pulley and that PCM and SLP headers ready to throw on just want to fix this first before I do
  10. #10 Re: P0300 Code. Random Misfire NEED HELP!
    Omaha, NE
    OBD-II Trouble Code: P0300 Random/Multiple Cylinder Misfire Detected
    A code P0300 may mean that one or more of the following has happened:
    •Faulty spark plugs or wires
    •Faulty coil (pack)
    •Faulty oxygen sensor(s)
    •Faulty fuel injector(s)
    •Burned exhaust valve
    •Faulty catalytic converter(s)
    •Stuck/blocked EGR valve / passages
    •Faulty camshaft position sensor
    •Defective computer
  11. #11 Re: P0300 Code. Random Misfire NEED HELP!
    Jul 2011
    Yeah I read all that. But if the cam sensor was bad that would throw a code same with the EGR. If the exhuast valve it run really ****ty when your driving. So I'm down to PCM or injector.
  12. #12 Re: P0300 Code. Random Misfire NEED HELP!
    Omaha, NE
    If it's a single injector it should be a cyl code instead of random, and I really doubt that the PCM just decided to go out.
    The CPS won't always throw a code when it is going bad.
    Can you still hear the fuel pump prime? Is the fuel filter clogged?
  13. #13 Re: P0300 Code. Random Misfire NEED HELP!
    Jul 2011
    Yeah true lol. Yeah fuel pump is good possibly could be a filter im going to do a fuel pressure test tmrw at my college and see what it's putting out. I wouldn't think a cam sensor would have anything to do misfire.
  14. #14 Re: P0300 Code. Random Misfire NEED HELP!
    Jul 2011
    But thank you for the help explicit
  15. #15 Re: P0300 Code. Random Misfire NEED HELP!
    Nov 2011
    Bayamon, Puerto Rico, Puerto Rico
    i would insist in coils or wires...
    i have had like 3 p0300 in like 2 weeks dealing with the details of the proyect.
    just recheck everything.
    i doubt it is PCM nor inyectors.
  16. #16 Re: P0300 Code. Random Misfire NEED HELP!
    Jul 2011
    Right on man. Yeah maybe i got a bad coil from napa or something but im working on it all day so hopefully I'll figure it out
  17. #17 Re: P0300 Code. Random Misfire NEED HELP!
    Jul 2011
    Well found out its cause a rough idle because sense I cut the cat off and the downstream o2 sensor it's dumping a lot of fuel into the motor. It's running really rich. We will see if anything changes once I throw that new PCM on.
  1. 4-5k rpm misfire, Code P0300.
    By trailshredder in forum Engine
    Last Post: 11-13-2011, 07:43 PM
  2. Code p0300 misfire caused by cat?
    By randywalsh in forum General Tech Discussion
    Last Post: 09-05-2011, 09:44 PM
  3. Code P0300 , mutiple random missfires, no fix yet
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2011, 11:28 PM
  4. Random Misfiring P0300 Code
    By spcguy88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2010, 09:44 PM
  5. random misfire P0300, many new parts
    By MarkB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2009, 11:10 PM
