Thread: what mods should i do next?
Results 1 to 20 of 27
  1. #1 what mods should i do next?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    Im rebuilding my engine due to a spun rod bearing... everything is back from machining and all balanced and ready to go. my mods so far are vs cam 90# springs new retainers and keeps, headers, intake,and a ported blower.
    now i know i want to get a tune but idk if I should buy a canned tune or have someone tune it for me. also i want to get a 180 t stat but not until my car is tuned.
    I was thinking of dropping down to a 3.4 or A 3.5 s/c pulley with supporting mods depending on how muck knock i will have if any. oh and i wanna do a shift kit in my trans as well
    what do you guys think ?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: what mods should i do next?
    Sep 2011
    Copperas Cove, TEXAS
    IC seems like a good mod now.
  3. #3 Re: what mods should i do next?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Get it dyno tuned, usually fuel trims from canned tunes can be outa whack. You should add a Downpipe or U bend delete to that list. You didnt mention plugs but id say AL 105's or 104's depending on your KR.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  4. #4 Re: what mods should i do next?
    Sep 2011
    palm harbor florida
    see i really didnt want to get into a ic setup. i mean the most ill run would be a 3.4 pulley
  5. #5 Re: what mods should i do next?
    Sep 2011
    palm harbor florida
    Quote Originally Posted by 94GrandPrixSE View Post
    that why i said supporting mods lol but i also have headers so no downpipe for me
  6. #6 Re: what mods should i do next?
    Sep 2011
    Then get a 3.4MPS and in car tune and call it done.
  7. #7 Re: what mods should i do next?
    Banned
    Jan 2013
    Colorado
    get it custom tuned then you won't have to worry about a shift kit
  8. #8 Re: what mods should i do next?
    Sep 2011
    palm harbor florida
    thats probably what ill do. also do i need colder plugs for just a cam and headers? or will autolite 106's be fine?
  9. #9 Re: what mods should i do next?
    Sep 2011
    palm harbor florida
    sorry 606's
  10. #10 Re: what mods should i do next?
    Sep 2011
    check the safely modding thread, plug info is in there. That's where I get my plug info.
  11. #11 Re: what mods should i do next?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Don't dyno tune, you won't be running WOT all the time... LOL find someone to do an nice in car street tune for you. If you go canned tune, 1) overkill 2) intense or 3800performance
    I'd have your intake/heads gasket matched. if you didn't already have port work done, it's the least you can do.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  12. #12 Re: what mods should i do next?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    I'd say with a VS and headers 605's might be your ticket. If you go to a 3.4 you'll probably be looking at 104's
  13. #13 Re: what mods should i do next?
    Sep 2011
    palm harbor florida
    Quote Originally Posted by dbextreme View Post
    Ya im not doing a dyno run lol. I cleaned my heads inside and our and they were hot tanked while they were apart.
  14. #14 Re: what mods should i do next?
    Sep 2011
    palm harbor florida
    Quote Originally Posted by addzradd View Post
    That's what I was thinking. ill probably go buy a set of 605's soon
  15. #15 Re: what mods should i do next?
    p&p the heads while it's apart.
  16. #16 Re: what mods should i do next?
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Have Gen v, vs cam setup, 60 injectors, 90 springs, and supporting mods running on a 3.4 for 91oct with 0kr but about 14-15 of timing due to tranny issues couldn't get the best tune, but it is good for now, till Paul gets the other tune done for e85 and have my tranny fixed should be a lot better. Running autolites 103, you should run the 104 if 91oct.
    If You Cant Hear The Whine You're Too Far Behind...
  17. #17 Re: what mods should i do next?
    Sep 2011
    palm harbor florida
    what all do you need for a gen v setup ? the blower the intake manifold and and a different tb right ? and odiously a tune and a different vacuum setup.
  18. #18 Re: what mods should i do next?
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    If you spent all the money to have it properly rebuilt then I would go big or go home. If your going to do a VS cam setup, I would have picked up a low mileage L26 and top swapped it from your other motor...
    1997 Regal GS, L26 N/A block, 'Reptile' Ported Gen 3 Blower w/3.5 pulley, VS cam, K&N Open Cone, Speed Daddy Headers, 3" cat and res, Dual 2.5" Dynomax mufflers w/C6 Corvette tips. PLX Wideband, Custom Dyno Tuned By Jeff @ Engineered Performance. Lucerne 17's, F-Body Brakes.
  19. #19 Re: what mods should i do next?
    Nov 2009
    Tennessee
    ^^^ What I did!!! LOVE it!!! But I had my L67 heads gasket matched... From what I read there's not much that can be done to improve the exhaust ports IIRC.
  20. #20 Re: what mods should i do next?
    Exhaust is where it's at
  1. Trade 98 GTP lite mods for GTP with mods
    By Shifty in forum Wanted To Trade
    Last Post: 10-20-2012, 07:52 PM
  2. Mods done.
    By GTP 40TH in forum General Tech Discussion
    Last Post: 07-23-2011, 08:41 AM
  3. First Mods, what should they be?
    By SteelCityTA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2009, 04:57 PM
