Thread: Need Compatible Computer
Results 1 to 6 of 6
  1. #1 Need Compatible Computer
    Nov 2011
    IL
    Hi Guys,
    I am looking for a standalone ecm that can control the 3800. (just engine management) or could I delete the trans options from stock ecm?
  2. #2 Re: Need Compatible Computer
    Feb 2009
    flintnasty MI
    I have used an AEM behind a 3800 manual fiero before, but it is a bit overkill for a normal horsepower setup (the advanced options for doing ignition help squeeze out a few HP passed 6k rpms)
    The factory ecu will work fine. A completely stock GTP or GT pcm from a 98 grand prix will (sorta) work on a manual transmission car without any changes. The pcm should be tuned for proper VSS input... without it you could run into a stumbling and stalling issue. You can also have the PCM tuned to retain a functioning check engine light.
  3. #3 Re: Need Compatible Computer
    Nov 2011
    IL
    What about the 00-02 computers? I am asking because I will be running an ecm and a standalone tcm.
  4. #4 Re: Need Compatible Computer
    Feb 2009
    flintnasty MI
    What transmission? 6Txxe? Factory obd2 PCMs are pretty awesome when it comes to transmissions... you can use a 4T60e, 4L60e, 4T80e, 4T65e all behind factory pcms. If you are going to try to use some sort of aftermarket transmission box for stupid features like tapshift or whatever, it is a complete waste of time tap shifting a 3 speed.
    It really doesnt matter what PCM you use if you have a tuner work on it, the 00+ files are a bit more powerful on a very small level, but they sometimes require security removal/tuning.
  5. #5 Re: Need Compatible Computer
    Nov 2011
    IL
    4t80e. I really don't want l start an argument on what trans is better... this is the trans I wna try at least. I thought the shift solenoids were backwards and the pcm couldn't run the 4t80e?
  6. #6 Re: Need Compatible Computer
    Feb 2009
    flintnasty MI
    backwards, but that is nothing a relay can not solve. And it is only one solenoid that is backwards.
    There is a writeup on how to convert a 80e to run a 65e pcm somewhere on the internet. There were 3 main things that needed to be helped, but otherthan that, it has been done before.
    And yes, the 4t80e is a fairly huge waste of time.... but if you want to give it a try go ahead. I ran a bone factory stock 4t65e for 2 years and 25k miles behind a 425+whp turbo 3800.... constantly abused as well.
  1. Compatible Transmissions?
    By ljmonnin12 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-12-2011, 08:59 PM
  2. Compatible parts???
    By Maloro619 in forum General Tech Discussion
    Last Post: 10-22-2010, 10:13 PM
  3. TOG Headers compatible with ZZP downpipe?
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2010, 04:18 AM
  4. Monsoon 6 disc XM or MP3 compatible
    By ponyfool in forum Audio, Security & Visual Electronics
    Last Post: 12-11-2008, 07:44 AM
  5. garage mod - GP compatible
    By TyroElite in forum Off Topic Discussion
    Last Post: 03-06-2008, 01:28 PM
