Thread: I have no idea
Results 1 to 4 of 4
  1. #1 I have no idea
    SE Level Member tracker1925's Avatar
    Wichita, Kansas
    When i have my new gtp at full throttle and at the top of second gear she will not shift unless i let out and slowly go over a 100 then put it back to the floor. How to fix it? Is it the PCM or is it something different?
    Ruckmister
  2. #2 Re: I have no idea
    Could be...also be your transmission slipping into 3rd...which means...yeah, no bueno.
  3. #3 Re: I have no idea
    I live here. TLSheff's Avatar
    Considering its a 99 GTP... normally they are well over 100k mileage and are getting tired. You said "new gtp"... new to you means you just bought it.... most likely has had a tough life and previous owner beat on it and the tranny is just tired.
    Simply race to 70mph... if you aren't winning by then you need to stop or call it a tie.
    Besides, street racing is illegal, highway speed limit is 70mph in Kansas, and if you tracking the car you need a new transmission before you go back (or make sure you have a friend with a trailer for when the tranny finally says F* You and dies)
  4. #4 Re: I have no idea
    Wichita, Kansas
    well its not like i use it to race, I use the speed to get around simi's on 96 on my way to work.
    Ruckmister
  1. Good Idea or Bad Idea?
    By Robby Avery in forum Turbo
    Last Post: 01-25-2011, 04:55 PM
  2. i have know idea
    By TurosGTP in forum General Tech Discussion
    Last Post: 08-11-2010, 08:51 PM
  3. Good idea - Bad idea?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 04:51 PM
  4. Got an idea- NEED HELP
    By Nickell in forum Visual/Body Modifications
    Last Post: 10-14-2009, 07:08 AM
