Thread: Engine rebuild
Results 1 to 20 of 23
Threaded View
SuperchargedFiero Engine rebuild 10-16-2011, 07:13 AM
SuperchargedFiero Re: Engine rebuild 10-16-2011, 01:00 PM
BillBoost37 Re: Engine rebuild 10-20-2011, 06:13 AM
blueguy Re: Engine rebuild 10-20-2011, 10:23 AM
Reptile Re: Engine rebuild 10-20-2011, 11:54 AM
SuperchargedFiero Re: Engine rebuild 10-21-2011, 04:34 AM
lambokit Re: Engine rebuild 10-21-2011, 05:57 AM
SuperchargedFiero Re: Engine rebuild 10-21-2011, 07:10 AM
SuperchargedFiero Re: Engine rebuild 10-21-2011, 08:48 AM
SuperchargedFiero Re: Engine rebuild 10-21-2011, 08:56 AM
SuperchargedFiero Re: Engine rebuild 10-25-2011, 05:19 PM
lambokit Re: Engine rebuild 10-25-2011, 09:06 PM
lambokit Re: Engine rebuild 10-25-2011, 09:22 PM
BillBoost37 Re: Engine rebuild 10-26-2011, 06:32 AM
SuperchargedFiero Re: Engine rebuild 10-26-2011, 07:09 AM
BillBoost37 Re: Engine rebuild 10-26-2011, 07:21 AM
SuperchargedFiero Re: Engine rebuild 10-26-2011, 07:05 AM
SuperchargedFiero Re: Engine rebuild 10-27-2011, 02:50 AM
BillBoost37 Re: Engine rebuild 10-27-2011, 05:35 AM
SuperchargedFiero Re: Engine rebuild 10-27-2011, 02:26 PM
SuperchargedFiero Re: Engine rebuild 11-20-2011, 02:36 PM
SuperchargedFiero Re: Engine rebuild 11-21-2011, 01:25 AM
SuperchargedFiero Re: Engine rebuild 11-21-2011, 05:43 PM
  1. #1 Engine rebuild
    SE Level Member SuperchargedFiero's Avatar
    Jul 2011
    The Netherlands
    Hi everyone
    It's some time ago that i ask some questions regarding a engine rebuild form people that now were they are talking about (this is the place)
    And now that i finely got the stuff i orderd from ZZP like.
    1xRollmaster timing set Model: Double
    1xValve Seals Option 1:Set of 12
    1xEngine gasket kit Engine:L67 Option 1:add Felpro head gaskets
    1xValve Spring Retainers Model:Modified steel
    1xFront cover gasket Model:standard paper
    1xThermostats Model:180
    1xClevite 77 Bearings Option 1:Main bearings (standard)
    1xClevite 77 Bearings Option 1:Rod bearings (standard)
    1xPiston rings Size:standard bore rings
    1xCrow Cams valve springs Model:130 lb CrowSprings
    1xX-P HOT Cam
    1xARP Head Studs for the 3800 Option 1:standard 6 point nuts 193-4001
    1xSupercharger Coupler
    1xEaton Rebuild Parts Model:M90 Option 1:Seal + snout and needle bearings
    1xZZP Modular Pulley System Size:3.0 Color:Clear
    1xHydraulic Roller Lifters By Competition Cams Model:OE-R 875
    I send my blok to a shop to check and if needed do boring/honing on the cylinders.Got the engine 1 week later back and it looked real nice.
    now i started to rebuild the engine and find out that the most bolts are Torque to yield ,and can't use the old bolts
    What is the best way to. Do i need to use new stock replace bolts or
    Order the arp main studs bolts with the arp connecting rod bolts
    The thing is on the site of ZZP there is a text quote Block line boring is recommended after the install of main studs / Machine shop work on the rods is required when changing the rod bolts to avoid spinning a bearing
    Last edited by SuperchargedFiero; 10-16-2011 at 07:14 AM. Reason: forgot one thing
  1. Engine Rebuild
    By NHRA21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2011, 07:48 PM
  2. Engine Rebuild/ Sub questions
    By joliver2011 in forum General Tech Discussion
    Last Post: 11-22-2010, 07:44 PM
  3. Engine and Trans rebuild??
    By EarlyGTDriver in forum General Tech Discussion
    Last Post: 03-08-2010, 11:35 PM
  4. Engine rebuild
    By MBruneaux in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-05-2010, 01:10 PM
  5. Rebuild or crate engine
    By That Guy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 11:12 PM
