Thread: Supercharger Snout Leaking??
Results 1 to 16 of 16
  1. #1 Supercharger Snout Leaking??
    Donating Users crock's Avatar
    Traverse City, Michigan
    There is something either coming from the supercharger or somewhere, but it is oil. It smells like supercharger oil. I was just wondering what you guys thought the leak may be? It leaks onto the top of the manifold right by the coolant elbow. Also, as I drive I can smell the oil burning.
    Thank you!
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  2. #2 Re: Supercharger Snout Leaking??
    Remove snout.
    Seal snout against rotor pack with anaerobic sealer.
    Bolt snout back down.
    Fill up with oil.
    Done.
  3. #3 Re: Supercharger Snout Leaking??
    Thought you had to take pulley and everything off to fix it? And just run the sealer all around where the snout meets the rotor pack?
  4. #4 Re: Supercharger Snout Leaking??
    Quote Originally Posted by crock View Post
    You only have to remove the pulley if the snout seal is leaking.
    Is there fluid on the hood?
  5. #5 Re: Supercharger Snout Leaking??
    Replacing a worn out supercharger coupler on 3.8 GM engines - YouTube this is a how to replace a coupler, but its waht you need to do to re seal it.
  6. #6 Re: Supercharger Snout Leaking??
    No fluid on the hood. Just going onto the manifold. And those Valve cover gaskets are new. Basically, it smells like crap so I know its supercharger fluid
    And I saw the video but I dont own a press or a puller.
  7. #7 Re: Supercharger Snout Leaking??
    So....get Brian (Reptile) to get you a good snout?
    Idearz son
  8. #8 Re: Supercharger Snout Leaking??
    you can leave the pulley on the snout and still remove the snout, whole job takes about 30 minutes or so. easy.
  9. #9 Re: Supercharger Snout Leaking??
    So its junk then? That pisses me off because it was replaced at around 70k. Has like 128k on it now...
  10. #10 Re: Supercharger Snout Leaking??
    Yea. I know. But, I just dont own the tools to rebuild it myself lol.
  11. #11 Re: Supercharger Snout Leaking??
    GT Level Member Remnant King's Avatar
    Nov 2010
    Michigan
    It doesn't need rebuilding, all you need is a socket wrench, remove the oil, remove the bolts. I believe it's ten of them open it up, apply the sealer around the edges and close it back up and tighten the screws, simple.
    2000 Midnight Blue Grand Prix GTP Coupe
  12. #12 Re: Supercharger Snout Leaking??
    Thats all? So it isnt anything serious then? Good. Can I use synthic oil for now until the GM stuff comes in?
  13. #13 Re: Supercharger Snout Leaking??
    Yup...
  14. #14 Re: Supercharger Snout Leaking??
    Sounds like I actually have something to do tonight. If I wasnt so introvert, I would get out...
  15. #15 Re: Supercharger Snout Leaking??
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Nick: can you seriously use syntetic oil instead?
    Crock: does it also leave deposits inside the pulley or underneath the snout? mine does that sh1t, but it's the snout seal that's leaking.
  16. #16 Re: Supercharger Snout Leaking??
    It's up to you...
    thread seen here...lots and lots of info.
    http://www.grandprixforums.net/how-o...oil-49499.html
  1. Removing Supercharger Snout Oil
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 10-05-2012, 01:56 PM
  2. leaking s/c snout?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 07:47 PM
  3. Report: Motor Oil In The Supercharger Snout
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2008, 07:32 PM
