Thread: Mass air flow sensor
Results 1 to 9 of 9
  1. #1 Mass air flow sensor
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    When i change my engine from n/a to s/c do i need to change my maf from one from the gtp?
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  2. #2 Re: Mass air flow sensor
    TDCRacing
    Guest
    Nope, But you will have to do a mass air flow tune after it is all done with a tuner that way your car will run right.
  3. #3 Re: Mass air flow sensor
    Apr 2008
    ny
    Quote Originally Posted by TDCRacing View Post
    I don't have or know anyone who has a tuner, should i just get a new one?
  4. #4 Re: Mass air flow sensor
    TDCRacing
    Guest
    Quote Originally Posted by duane9586 View Post
    The maf sensors are the same. The only way to get it perfect is with a tuner. Will you also be swapping your pcm for a gtp pcm?
  5. #5 Re: Mass air flow sensor
    Apr 2008
    ny
    Overkill is making me a pcm.
  6. #6 Re: Mass air flow sensor
    TDCRacing
    Guest
    Then thats as close as your going to be able to get it. and no changing the maf wont be nessary.
  7. #7 Re: Mass air flow sensor
    Apr 2008
    ny
    Thanks for all of your help...
  8. #8 Re: Mass air flow sensor
    TDCRacing
    Guest
    No problem. Have fun with it.
  9. #9 Re: Mass air flow sensor
    Apr 2008
    ny
    I have a feeling I will
  1. Interesting demonstration of Laminar flow
    Last Post: 07-07-2008, 02:10 PM
  2. New kid on the block from Mass
    By Brady_to_Moss in forum Introductions/Noob Questions
    Last Post: 06-10-2008, 11:21 PM
  3. Easy Performance Flow Charger
    By t24moore in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2008, 07:13 PM
  4. Intercooler Flow???
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 08:45 PM
