Thread: Help with cruise rpms
Results 1 to 15 of 15
  1. #1 Help with cruise rpms
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    I've just recently noticed that when I am cruising around 100km/h (60mph) my rpm's jump up and down between 1500 and 1000.
    I have a video that I will post when I get home from work.
    Any ideas as to what would be causing this?
    I have cleaned my MAF, IAT and throttle body, but no difference.
    No CEL.
    Please help,
    Thanks
  2. #2 Re: Help with cruise rpms
    trans jumping in and out of lockup??
    MAybe get the trans scanned for codes and see whats up.
  3. #3 Re: Help with cruise rpms
    Lockup is probably more. Although the osciallation could be the issue.
    When was the car's last tune of up spark plugs and wires?
  4. #4 Re: Help with cruise rpms
    May 2011
    I just put new ngk wires on and plugs were done in may 2011.
    When I changed the wires I noticed one of the coil pack connections was kind of rusted, and I forgot to wire brush it off, I'm going to try that tonight and see if I notice a change.
  5. #5 Re: Help with cruise rpms
    May 2011
    I forgot to add that it was after I got my overkill pcm that it started.
  6. #6 Re: Help with cruise rpms
    May 2011
    here is the video to show what I mean.
  7. #7 Re: Help with cruise rpms
    May 2011
    So i put all new copper plugs and it is still doing it. so i guess its the lockup..
  8. #8 Re: Help with cruise rpms
    How did the wires and coils look?
  9. #9 Re: Help with cruise rpms
    May 2011
    wires were good there pretty much brand new. the coils do seem to have some stuff on them, i wire brushed them as much as i could. but theres still some rust/black stuff left.
  10. #10 Re: Help with cruise rpms
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Does this happen with your foot on the gas pedal or with cruise control on?
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  11. #11 Re: Help with cruise rpms
    May 2011
    Quote Originally Posted by tms8582 View Post
    No it only happens when I am coasting.
  12. #12 Re: Help with cruise rpms
    May 2011
    sorry to bring up an old post, but how would I fix this problem, is it worth the trouble?
  13. #13 Re: Help with cruise rpms
    May 2011
    updated video of problem. and a thread of all the troubleshooting I have done: EricTheCarGuy
  14. #14 Re: Help with cruise rpms
    what are you scanning with?
  15. #15 Re: Help with cruise rpms
    May 2011
    Quote Originally Posted by gtpsleeper View Post
    A Scangauge II
  1. Stuttering at low RPMs
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2011, 08:38 PM
  2. No RPMs..?
    By GTBabyGirl in forum Audio, Security & Visual Electronics
    Last Post: 10-14-2011, 07:46 PM
  3. Rpms on the highway?????
    By nickdemio in forum General Tech Discussion
    Last Post: 05-13-2011, 12:27 AM
  4. RPMs...??
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 11:47 PM
  5. Stalling, low RPMs
    By jdamico84 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-05-2009, 01:01 PM
