Thread: SES light on P0401
Results 1 to 7 of 7
  1. #1 SES light on P0401
    Sep 2011
    kansas
    I just did the LIM gasket and the valve cover gaskets on my grand prix gtp. Ever since I finished I keep getting the P0401 code(insufficient EGR (exhaust gas recirculation) flow). Any idea where to start. There where no codes before I did the LIM gasket.
  2. #2 Re: SES light on P0401
    utah
    Makes sure the egr is attached and sealed
  3. #3 Re: SES light on P0401
    Sep 2011
    kansas
    I didn't take the egr valve off, just the tube to the manifold.
  4. #4 Re: SES light on P0401
    SE Level Member baker01gt's Avatar
    Sep 2011
    houston, TX
    i had the same code for a while.. couldnt figure it out.. i pulled the egr valve off and cleaned inside and replaced the egr valve and it finally turned off.. (changing the egr valve is not always the case, just happenes it was my prob.. i first replaced it and the light came back on after a month and ended up the new egr valve was a bad part).. goodluck!! (i also ran some seafoam so try and remove any carbon build-up)
  5. #5 Re: SES light on P0401
    utah
    you might have bumped it or otherwise hit it. give it a shot
  6. #6 Re: SES light on P0401
    Sep 2011
    kansas
    Will do tomorrow and post back.
  7. #7 Re: SES light on P0401
    Check your map sensor. That's how the flow is monitored by the pcm.
  1. Need help fixing EGR code P0401!!!
    By grprx01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2022, 06:48 PM
  2. P0401 code now...
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2011, 02:21 PM
  3. P0401 Code
    By screechingdemon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2011, 09:24 AM
  4. code P0401
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 01:30 PM
  5. P0305 and P0401 96 3.1L Fixed
    By alacran in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-13-2008, 08:49 PM
