Thread: TCS wont turn on!
Results 1 to 10 of 10
  1. #1 TCS wont turn on!
    Nov 2011
    Kelowna, Canada
    Ok so drove to the gym and when I came out my tcs was somehow turned off and now will not turn back on. Thoughts?
  2. #2 Re: TCS wont turn on!
    Willoughby, Ohio
    is the TRAC OFF light on? along with the ABS light?
  3. #3 Re: TCS wont turn on!
    Nov 2011
    Kelowna, Canada
    Quote Originally Posted by CTKGP09 View Post
    Yes but the ABS light has been off for awhile. Trac off just came on
  4. #4 Re: TCS wont turn on!
    Nov 2011
    Kelowna, Canada
    no input from anybody?
  5. #5 Re: TCS wont turn on!
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Wheel bearing(s).
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  6. #6 Re: TCS wont turn on!
    SE Level Member OldFart's Avatar
    Sep 2011
    Ontario, Canada
    Yup. Speed sensor, which is located within the wheel bearing.
    Stock 2001 GTP
  7. #7 Re: TCS wont turn on!
    Nov 2011
    Kelowna, Canada
    I would assume its probably a front wheel bearing since its affecting the abs and tcs. Havent had a chance to jack up the car a check them yet. Hopefully today sometime.
    Thanks for the help.
  8. #8 Re: TCS wont turn on!
    Willoughby, Ohio
    even if they are mechanically solid, the sensor inside could be shot, i have 2 GPs like that right now -_-
  9. #9 Re: TCS wont turn on!
    when the TCS light is on, that means the system is OFF, just so you know.
    and we have 4 wheel disc brakes with 4 wheel abs.
    So get the car scanned to see exactly what wheel bearing is bad.
  10. #10 Re: TCS wont turn on!
    Nov 2011
    Kelowna, Canada
    Yes I realise that. I was asking about the fronts because I wasnt sure if the tcs and abs were connected to eachother, as they arent on many cars. So figuring that way I was under the impression if the tcs wasnt working the issue was probably in the front end and not the rear
  1. AC Fan wont turn on
    By kaminski347 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2011, 10:41 PM
  2. TCS wont turn on
    By jmalin72207 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2010, 01:19 AM
  3. car wont let me turn it off??
    By 02blackgpgt in forum General Tech Discussion
    Last Post: 04-25-2009, 08:14 AM
  4. My Car wont Turn off !!!
    By Billyboi6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-15-2008, 01:02 AM
  5. Car wont turn off !?!
    By Billyboi6 in forum Northeast
    Last Post: 11-11-2008, 12:54 PM
