Another thing you might want to do is check that the engine is reading the proper coolant temperature.
Dont forget that tire pressure, and even the type of tire will effect your gas milage along with a good wheel alignment.
I picked up a solid 3mpg on the highway after installing 4 new tires and a wheel alighnment. Also make sure you e-brake is fully realeased.
Hope this helps!
