Thread: Loosing coolant, engine running hot and rough
Results 1 to 5 of 5
  1. #1 Loosing coolant, engine running hot and rough
    Nov 2011
    Mankato, MN
    Hey all first post just registered.
    So my 99 grand prix gtp with 233,xxx miles started loosing coolant then ran a tad hot about a month ago so i just refilled the overflow tank and it was all good but in the last week or two the engine heats up quickly and runs pretty hot. After running awhile there is the sweet smell of anti freeze outside the car, not too strong though. The heat is taking longer than usual to warm up as well. It also has started running kind of rough when in idle, Im not sure if that is related to this or not.
    I just changed my oil and did not notice anything in there, nothing milky, watery, ect. I cannot detect any leaks either, tried putting cardboard down, no leaks underneath the engine. Only thing I could thing of is it is coming out my tail pipe?
    The check engine light just came on so I am going to get that read now, also going to check the radiator to see if there is any antifreeze actually in there or if the antifreeze is just staying in the overflow tank and not getting to the radiator.
    Any ideas or advice would be great thanks
    Luke
  2. #2 Re: Loosing coolant, engine running hot and rough
    Luke..
    I'd wonder...every replaced the LIM gaskets. Lower Intake Manifold gaskets that is.
  3. #3 Re: Loosing coolant, engine running hot and rough
    St. Louis
    I'd be willing to bet that the CEL will come up as a misfire on cyl #x, either that or multiple misfires. I'm with Bill on this one. Sounds like time for LIM gasket replacement.
  4. #4 Re: Loosing coolant, engine running hot and rough
    Nov 2011
    Mankato, MN
    From my knowledge it has not been replaced, in the last 40k miles that is. So I took a better look at it and was able to find a small in the hose that goes from the radiator to the overflow tank but that part is discontinued according to the GM dealership so I took a hose about the same size and used that until the part off the internet arrives. Do you guy still think I should replace the LIM gasket?
  5. #5 Re: Loosing coolant, engine running hot and rough
    Brewcity, WI
    Quote Originally Posted by larsol1 View Post
    If it still has the black plastic gaskets, then yes. I'm sure your motor is probably dirty, but you should be able to see the color of the gaskets. I'm sure your going to have to clean oil and crap off, but you should be able to see if its black (plastic) or silver (metal) which would be what you want are the metal ones.
    Self-denied SMGPFC member #1
    SEARCH works!
  1. Loosing coolant somewhere...please help
    By tgarison in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2011, 10:21 PM
  2. running rough
    By BOOSTED GP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2011, 11:58 AM
  3. Engine running rough?
    By 05PontiacGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2010, 06:04 PM
  4. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  5. 01 GTP running rough
    By tazgtp in forum General Tech Discussion
    Last Post: 03-28-2010, 04:10 PM
