Thread: Water pump
Results 1 to 5 of 5
  1. #1 Water pump
    Dec 2010
    Wesley Chapel, Fla
    Water pump question for 2004 gtp
    While attempting to change the water pump all went well until
    I got to the bolt behind the power steering pump pulley hard to see
    anything in that area i can feel only one bolt threw the holes behind
    the pulley, my question is what are my options here?
  2. #2 Re: Water pump
    Dec 2010
    Wesley Chapel, Fla
    I got it! thanks to similar threads, I did search and didn't see any of these
    threads there.
  3. #3 Re: Water pump
    the p/s pump has 2 bolts, top and bottom in the pulley holes, and the idle pulley needs to come off too, its blocking the bottom bolt of the water pump, needs a t-45 to get it off.
    looks like this after the pumps off. the closest idler by the crank pulleys comes off.
  4. #4 Re: Water pump
    Dec 2010
    Wesley Chapel, Fla
    ^ Thank you Sir, It was easyier than thought even putting the power steering
    bolts back in threw those holes.
  5. #5 Re: Water pump
    yeah its not to bad, just part pulling at its best .
  1. Water pump HELP
    By cincygoat in forum Off Topic Discussion
    Last Post: 06-26-2011, 06:57 PM
  2. Water Pump Help
    By thewaitinggame in forum General Tech Discussion
    Last Post: 02-18-2011, 07:57 PM
  3. Water Pump
    By carl06GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 07:58 AM
  4. Water Pump
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 10:19 PM
  5. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
