Thread: 97-98 maf tables diff than 99+?
Results 1 to 6 of 6
  1. #1 97-98 maf tables diff than 99+?
    I know the maf are diff but i was wondering if a 99 gtp pcm would work in my 98. I think this would be beneficial to all if any that are wondering the same thing.
  2. #2 Re: 97-98 maf tables diff than 99+?
    Portland Oregon
    I'm pretty sure the maf tables are different. I believe on the 99+ maf tables the numbers are going to be less
  3. #3 Re: 97-98 maf tables diff than 99+?
    The tables are different.
  4. #4 Re: 97-98 maf tables diff than 99+?
    Florida
    even with tuning i know some 99+ pcms will not accept a 98 file... i have a 99 GTP pcm and it would not let me flash a 98 file to it. i ended up getting another 98 PCM and had not problems.
  5. #5 Re: 97-98 maf tables diff than 99+?
    HUH?
    Just copy the maf table from the year you need into your bin. No need to put the entire bin in. Just the table you are changing.
  6. #6 Re: 97-98 maf tables diff than 99+?
    Florida
    yeah that too lol... from the way its worded it sounds like they want to swap the pcms. yes changing the table in the bin file is the way to do it. no need to touch the pcm physically
  1. Wheel coffee tables.
    By AWeb80 in forum Off Topic Discussion
    Last Post: 05-22-2011, 02:31 PM
  2. Order to tune tables in?
    By Bedwards in forum PCM Tuning
    Last Post: 11-17-2010, 11:05 PM
  3. 42.5# injector tables for DHP PT
    By Sabrewings in forum PCM Tuning
    Last Post: 08-18-2009, 04:44 PM
  4. LT1 Maf tables
    By FoSHO99 in forum General Tech Discussion
    Last Post: 04-21-2009, 01:11 PM
  5. Tranny whine after diff and diff case replace...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2008, 09:27 PM
