Thread: Front end shake from engine
Results 1 to 6 of 6
  1. #1 Front end shake from engine
    Sep 2011
    Canada
    OK, when I accellerate I feel a shaking from the front of the car. Even when I maintain a regular speed on a slight incline I can feel like the car is going up and down. I let off the gas and it dtops. Would modifying the dogbone bushings help or is it an engine mount? I'm still learning what the trouble spots are with these cars.
  2. #2 Re: Front end shake from engine
    Jun 2011
    Detroit, MI
    mine does something like that too, idk
    iLoveSpade
  3. #3 Re: Front end shake from engine
    You likely have a bad axle.
    The way you know is ...it's acceleration or load related. So it's something that has pressure when you are on the throttle.
    Mounts would clunk etc when you go into gear, when you are on/off the gas, not steady throttle.
  4. #4 Re: Front end shake from engine
    Florida
    does it change when turning? or worse at a certain speed? if so could be a wheel bearing...
  5. #5 Re: Front end shake from engine
    SE Level Member RegalGShocker's Avatar
    Milwaukee, WI
    Its hard to say over the internet but torque converter might be something else to look into.
  6. #6 Re: Front end shake from engine
    Sep 2011
    Canada
    Well, it doesn't do it all the time. Mostly on hills. It's fine on the highway in cruise control. It's mostly when I'm accellerating hard, or going uphill. There's no noise from the tranny. I know what the whine sounds like.
    I checked the wheel bearings and there's no shake or play. No ABS light either. Tranny fluid is clear red. I know I have to change the fuel pump (tomorrow) so maybe when it's accellerating it's not getting enough fuel. I hope that is the issue.
    Also, can anyone tell me what the typical tranny problems are with these cars? What mileage do they start to go bad? Can anything be done to prolong the life of the tranny? (Yes I know about changing the fluid to Dexron VI). I've had a 2001 Aurora(Same tranny as a GP GT) and Cutlass Supreme with bad trannys. I thought the GTP tranny was more beefed up and lasted longer but from what I've been reading oin the forum I'm now worried. My tranny doesn't seem to have an issue now.
  1. HID Shake
    By NewBoost1997 in forum General Tech Discussion
    Last Post: 09-21-2011, 10:49 AM
  2. Front end shake/vibrate please help
    By cbcollins in forum Introductions/Noob Questions
    Last Post: 07-01-2011, 07:03 AM
  3. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  4. Front/Rear/Engine Update!
    By Nickell in forum Visual/Body Modifications
    Last Post: 03-28-2010, 04:17 PM
  5. Rattling noise from the front of engine
    By tjhgtp86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2010, 10:10 AM
