Thread: Knock Retard Issue
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Knock Retard Issue
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    So, it's just an open cone then...right off of the MAF sensor.
    Try putting a little piece of pipe inbetween the MAF and the filter and see if that cures it.
    Will do, I'll post the result upon further testing
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  2. #22 Re: Knock Retard Issue
    Jan 1970
    Maquoketa, Iowa
    It's going to be warmer at idle because there is no airflow at 0 mph in a hotass engine bay. At cruise or above it should be within 10-20* of ambient.
    What have you changed since the tune?
  3. #23 Re: Knock Retard Issue
    Dec 2010
    Montreal, Canada
    Quote Originally Posted by FoSHO99 View Post
    Only the air filter...
    Previous setup : Inside-Out Cone Filter - Aluminum Pipe - MAF Sensor - TB
    Current setup : Dryflow 9" Cone Filter - MAF Sensor - TB
  4. #24 Re: Knock Retard Issue
    See, probably skewed the MAF readings.
    Go back to what you had.
  5. #25 Re: Knock Retard Issue
    GTX Level Member crbquist's Avatar
    Massachusetts
    If you are running a "newer" style aeroforce gauge, then make sure you are scanning under "knock 1", and not the knock 2 or knock 3 parameter. I drove with the gauge for a year thinking I had crazy spikes of KR at WOT (sometimes up to 7-8*), because I had it set to knock 2 and not knock 1. Knock 1 is for GM cars while knock 2 and 3 are for other vehicles. With it set to the correct scanning parameter for KR, I now just get "blips" of knock under hard throttle usually under 1* depending on the weather. Just an FYI...
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  6. #26 Re: Knock Retard Issue
    Dec 2010
    Montreal, Canada
    Quote Originally Posted by crbquist View Post
    Yeah it's under knock 1, for some reason I took the time to read the booklet So after 94 and putting in back to the old setup I have blips of 3-4, 5 under big stress but drops to 0 afterwards...I think spikes are false knock. Neways, like I said, I haven't seen performance issues yet...I can stop worrying about it I think
  7. #27 Re: Knock Retard Issue
    KR is the result of the sensor reading something.
    Whether or not its detonation is another story.
    Regardless it will affect performance by pulling timing.
  1. Knock retard on a NA
    By Ophidia in forum General Tech Discussion
    Last Post: 02-22-2012, 11:10 PM
  2. Attack of the knock retard
    By shawnschuldt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2011, 06:51 PM
  3. Knock Retard when accelerating
    By xxmattfxx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2011, 06:33 PM
  4. Knock Retard - Stock
    By rfmgtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2011, 02:05 AM
  5. Knock Retard
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 01:05 AM
