Thread: p0101, p0205, p0305?
Results 1 to 13 of 13
  1. #1 p0101, p0205, p0305?
    GT Level Member Knightmare's Avatar
    Jul 2011
    Frederica, DE
    Hi, so I finally got my GTP back together..but it's throwing these codes...the SES light is solid under 30Mph and flashes when I get above that...I know that one of the codes is for a miss on cylinder 5...what could be causing it? thanks
  2. #2 Re: p0101, p0205, p0305?
    Florida
    p0101, p0205, p0305P0305 is a misfire for Cylinder #5 like you said.
    P0101 is Mass Air Flow (MAF) Circuit Range/Performance Problem
    P0205 is Cylinder 5 Injector Circuit Malfunction
    i would check that injector and make sure it is connected and there are crossed wires or something wrong there. id also check the wires for the MAF as that is your other code
  3. #3 Re: p0101, p0205, p0305?
    Jul 2011
    Frederica, DE
    thanks phoenix...gonna go check it out now....could the injector be the reason for the misfire?
  4. #4 Re: p0101, p0205, p0305?
    Florida
    deff
  5. #5 Re: p0101, p0205, p0305?
    Jul 2011
    Frederica, DE
    ok thanks gonna go check it out
  6. #6 Re: p0101, p0205, p0305?
    Jul 2011
    Frederica, DE
    ok..so as far as i can tell......the injector is seated fine....plug is fine.....maf plug seemed ok...
  7. #7 Re: p0101, p0205, p0305?
    Jul 2011
    Frederica, DE
    maybe i should find someone with more knowledge than myself lol
  8. #8 Re: p0101, p0205, p0305?
    Or ask questions and learn more to be more knowledgeable.
  9. #9 Re: p0101, p0205, p0305?
    Feb 2009
    Virginia
    Sometimes it just takes trial and error...LOTS of knowledge on these forums :> Ask away!
    11 is louder than 10!
  10. #10 Re: p0101, p0205, p0305?
    Swap the injector over and see if the misfire follows the injector...if it does, then you have a bum injector.
  11. #11 Re: p0101, p0205, p0305?
    Jul 2011
    Frederica, DE
    @billboost-I do ask questions lol, that's why the thread is here
    @I800Collect- I plan on asking as many as needed
    @bluegtp91- That sounds like a good idea will def try it..gonna suck though, I dont have a code reader, so gotta swap and run to autozone
  12. #12 Re: p0101, p0205, p0305?
    GT Level Member nicks98gtp's Avatar
    michigan
    if youve got a voltmeter that will read resistance take a measurement of the injector on cyl.5. when mine went bad it did the same thing, checked resistances between a couple injectors and found it was way low. the ranges of the good injectors were around 11.2-11.6 ohms.
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  13. #13 Re: p0101, p0205, p0305?
    Jul 2011
    Frederica, DE
    Quote Originally Posted by nicks98gtp View Post
    maybe tomorrow thanks though
  1. Cylinder 5 misfire trouble code P0305
    By michellebuck76 in forum General Tech Discussion
    Last Post: 04-11-2013, 06:02 PM
  2. Problem solved p0101
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-05-2010, 11:21 AM
  3. P0101 and p0172 Codes??
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2010, 11:55 AM
  4. P0101 Code
    By JB381 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2010, 12:20 AM
  5. P0305 and P0401 96 3.1L Fixed
    By alacran in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-13-2008, 08:49 PM
