It looks like the stock fuel pump in my GTP is failing when do a pressure check it reads 25psi on prime and only about 32psi while running. It also loses it's prime in about 2 min if you don't try to start it right away.
I was wondering should I just go with a stock pump or upgrade
My mods are 3.25 pulley full 3" exhaust, CAI, 103 plugs, 3800performance ECU stage 1, and fuel pump rewire.
Thanks guys
