Thread: Leaking oil at pulley end on S/C
Results 1 to 20 of 22
  1. #1 Leaking oil at pulley end on S/C
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Leaking at pulley end on '99 supercharger - Is there a seal that can easily be replaced? Or, am I looking at more extensive repair. A link to a how-to would be great if so. Tried searching, but didn't come up with much.
    Currently, I'm not running the S/C - (http://www.grandprixforums.net/drive...elt-52195.html)
  2. #2 Re: Leaking oil at pulley end on S/C
    Rollingperformance.com
    You need a seal.
  3. #3 Re: Leaking oil at pulley end on S/C
    Apr 2009
    Thanks!
    You are the man!
  4. #4 Re: Leaking oil at pulley end on S/C
    Shhhh you'll ruin my mean guy rep
  5. #5 Re: Leaking oil at pulley end on S/C
    Apr 2009
    Bill, how much oil will I lose when I replace the seal? Just wondering whether to buy two bottles or just one.
  6. #6 Re: Leaking oil at pulley end on S/C
    Get two and change the oil out anyway. Clean oil = a happy car. I doubt you'll actually lose any though.
  7. #7 Re: Leaking oil at pulley end on S/C
    Apr 2009
    Just changed the oil out about 15,000 miles ago. Sucked it all out with a syringe and replaced with two new bottles. Do the same again, still?
  8. #8 Re: Leaking oil at pulley end on S/C
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    wheres a good place i can send my gen 5 to get rebuilt
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  9. #9 Re: Leaking oil at pulley end on S/C
    Salt Lake City Utah.. that's where I'd send it
    What needs to be rebuilt?
  10. #10 Re: Leaking oil at pulley end on S/C
    i just want the whole thing rebuit the guy i bought it from had two of them and i guess the second was in really ****ty condition so right now its gettin polished and than im gonna have it rebuilt just to make sure u know im also gonna talk to the hs about gettin my rockers rebuilt as well. the problem here in salt lake is nobody reuilds s/c
    SMGPFC #77
  11. #11 Re: Leaking oil at pulley end on S/C
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    swap it with gear lub
  12. #12 Re: Leaking oil at pulley end on S/C
    Apr 2009
    Quote Originally Posted by Wisconsingrandprix View Post
    Please explain.
  13. #13 Re: Leaking oil at pulley end on S/C
    GM has said we can use Mobil 1, but gear lube is thicker than you want to put into the SC. You want a thin lubricant, not thick.
    It's pretty easy to rebuld. Take a look at the site linked above and check out the rebluiding.
  14. #14 Re: Leaking oil at pulley end on S/C
    Apr 2009
    I will just stick with the GM oil that originally came in it. The Mobil 1 idea, though, would be a good thing to remember if I get in a pinch some time.
  15. #15 Re: Leaking oil at pulley end on S/C
    ISO 32 is similar to 0W-20 which is similar to GM supercharger fluid.
    Gm says Mobil 1 5W-30 in southern states all year round. In northern states, you should switch back to GM stuff for the winter.
    Or run ISO 32 or 0W-20.
    But the GM stuff has the same cost, same performance, lasts much longer.
  16. #16 Re: Leaking oil at pulley end on S/C
    Apr 2009
    Can the seal be replaced without removing the snout from the supercharger body? By these instructions, it sounds like it needs to be off, but this is also talking about a rebuild, though.
    Eaton snout rebuild
  17. #17 Re: Leaking oil at pulley end on S/C
    just pump the old fluid out, and take it off, all you need to do is, remove the belts, alternator, flop it to the side, unbolt the snout and slide it off. get new fluid, and some of that sealant for the s/c,(i forget the name of it) i used high heat rtv, its been holding for over a year now. very thin smear on both sides of the case and snout, is more than enough.
    im sure it would be easier to work on off the car.
  18. #18 Re: Leaking oil at pulley end on S/C
    Apr 2009
    crap, well, I wish I'd have known that before I bought the seal, or I would have gotten the coupler, too, if I'm going to have it off, anyhow. I guess it's my fault for not asking ahead of time.
  19. #19 Re: Leaking oil at pulley end on S/C
    Apr 2009
    Secondarily, why are there no posts on replacing the seal? Maybe I just can't find them, except for two. One is this:
    http://www.grandprixforums.net/snout...ent-12121.html
    The other is just someone trying to sell a polished snout with new seals. What gives??
