Thread: Engine Coolant Question
Results 1 to 12 of 12
  1. #1 Re: Engine Coolant Question
    SE Level Member hotshot's Avatar
    R.I.
    Make sure you check the coolant. If it is red it still has the factory dex-cool wich cannot be mixed with the yellow stuff. If you need to add you have to add dex-cool or a certian prestone that will say on the bottle that it is safe to mix with any other coolant. Otherwise it will gel up and or turn into a sand like slugde and that will be a problem.
    98 GTP - slp powerflo cat back, built tranny, AP104s, homemade FWI and intense 180 stat.
  2. #2 Re: Engine Coolant Question
    Jul 2008
    canada
    Thanks a lot for your valuable advise. I looked at the coolant bottle but there are no marks anywhere indicating LOW or FULL or something that tells me the limit. Can i fill upto half bottle?
  3. #3 Re: Engine Coolant Question
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    The line is barely above where the hose from the radiator connects. I would only go 25% if you don't see the line. btw there are no words just a raised line the same color as the bottle, which makes it hard to see.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #4 Re: Engine Coolant Question
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by hotshot View Post
    Green stuff cannot be mixed; if it is yellow it is supposed to be safe to add to any coolant. I have only seen the stuff made by Prestone.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  5. #5 Re: Engine Coolant Question
    Jul 2008
    canada
    I checekd the radiator. It's filled upto top. I also filled enough coolant in the reservoir bottle but my lights still stays on. this is what happens. When i start car in the morning it stays on for 5-7 minutes and after that it goes off. Could this be because of bad sensor? Where is the coolant level sensor in 1998 Grand Prix? Is this something i need to replace right away? By the way temperature stays within acceptable limits.
  1. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  2. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  3. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
  4. Coolant leaks
    By golden_c_ninja in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2008, 10:13 PM
  5. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
