Thread: Daytime running lights
Results 1 to 14 of 14
  1. #1 Daytime running lights
    Sep 2011
    cedar rapids
    So a few weeks ago I noticed when I pulled in my garage that my lights weren't on. I asked my daughter if she saw them on when I was following her and she said they weren't. This is during the daytime. At night they work just fine and after a few moments after pulling into the garage and shutting the door so it's dark they come on. Is this an expensive fix? And what is causing it? I know that I can turn them on manually but I don't bother doing that because I just know that I will forget to turn them off and come out to a dead battery. Let me know if this is worth bothering with or letting it go as long as they come on at night. Thanks!
  2. #2 Re: Daytime running lights
    GTX Level Member bandits grand prix's Avatar
    Jul 2010
    connecticut
    Quote Originally Posted by lucyboop View Post
    what is the problem? i dont understand..
  3. #3 Re: Daytime running lights
    Jul 2010
    connecticut
    try checking fuses
  4. #4 Re: Daytime running lights
    Sep 2011
    cedar rapids
    The problem is that the headlights should be on in the daytime automatically. I did some checking on the internet and it seems to be a really complicated problem, not just a simple fuse. I bought the car a year ago and they have always worked in the daytime but not now. What fuse would it be?
  5. #5 Re: Daytime running lights
    well why do you want lights on during the day?
  6. #6 Re: Daytime running lights
    Sep 2011
    cedar rapids
    Well, the reason for daytime running lights is that it is a proven fact that accidents are reduced. Also during rain, snow, and fog they are even more useful. I want to know how to fix it and if it is worth it, not a ? on why I want them on. Do you know how to fix it or not?
  7. #7 Re: Daytime running lights
    Jul 2011
    NW Ohio, USA
    Well, I'm not so sure this is your problem, but are your DRL's unplugged? Reason I'm wondering is cause I unplugged mine a week or so ago cause I don't need to be using up headlight bulb life during broad daylight....and cause I just wanted to (lol).
    Anyways, if you want to check just pop off the access panel on the left side of your dash (flat head screwdriver works great for this). The panel is by where the drivers door and dash meet so the door will have to be open, but after you've got it open just look inside for any unplugged wires. My DRL box was located inside this access panel and to the left, like towards the front of the car. The box that the cable should be plugged into looks kinda like a little silver heatsink. If you see the wire is unplugged, just plug it back in and viola! working DRL's. If that doesn't work I don't know what to say other than "I tried.... "
    I Gotz Moar Powar Than U Gotz
    The HWG Thread = Winning.
  8. #8 Re: Daytime running lights
    Ocala, FL
    When there's rain, snow, or fog.. I'd recommend just turning your headlights on
  9. #9 Re: Daytime running lights
    If the DRL's don't work...which I don't care about since I unplugged mine...GM did put a switch on the left side of the dash so you could manually turn on your headlights...
  10. #10 Re: Daytime running lights
    ok if ya wanna be like that... Id say either waste a tone of money on a mechanic to find that electrical problem in your switch/sending unit or... fix your left hand mod and turn them off and on yourself...
    and its not a "fact" that accidents are reduced, its a theory...
    the reason I asked why you even wanted them was because I was wondering if it was because you are concerned about the resale value or over all function of your head light assembly in regards to the daytime running lights not working. If this were the case it would have allowed us to help you more/ maybe answer your question quicker...
    last time i help a noob....
  11. #11 Re: Daytime running lights
    Sep 2011
    cedar rapids
    Wow, gtpsleeper, way to make me feel welcome on here by insulting my being new. I specifically asked in my post IF it was worth fixing or not. Apparently it's not. You don't need to insult me and if that's how you feel about new members, don't bother responding to us. I'm not stupid, I like having them on without having to constantly turn them on manually. Kind of how you surely like the convenience of your remote control for your TV I assume. If I want to waste my money having a mechanic fix it that's my business and none of your concern. I could care less about the resale value of my car as I intend on being it's last owner. It's not a THEORY either, there is proof. As far as you helping a noob, you never helped with anything! You only questioned me why I wanted them on. If that's your version of helping, then you need to look it up in the dictionary.
    To the others on here that responded, thank you. To 98L36, I checked and there isn't anything unplugged so who knows? Thanks for the suggestion though.
  12. #12 Re: Daytime running lights
    just giving it how im getting it brah...
    and no there is no facts behind it being safer... but whatever helps ya sleep
    good luck
  13. #13 Re: Daytime running lights
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    yeah id say if you have checked all the cheap options and it isnt any of those dont really worry about it. Yeah there is proof about it causing less accidents but hey think on the bright side since they are only running at night then the life of the bulbs are extended I just put HID;s in my gtp and unplugged the DRL cuz i didn't want it running during the day cuz i hate how cars look with headlights running during the day lol
  14. #14 Re: Daytime running lights
    GT Level Member Deviq's Avatar
    SE WI
    I would guess checking out the DRL Diode 98L36 talked about. Seems to me if unplugging it causes your condition then it going bad would cause the same issue, right? But only a guess. Check out BackinBlacks website, he kinda explains what 98L36 is talking about.
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  1. Daytime running lights
    By RayGTP in forum Audio, Security & Visual Electronics
    Last Post: 08-02-2012, 10:14 PM
  2. Daytime Running Lights
    By joeringo11 in forum 04+ Specifics
    Last Post: 01-27-2012, 12:07 PM
  3. daytime running lights
    By 1navyguy in forum General Tech Discussion
    Last Post: 06-30-2011, 06:27 PM
  4. 02 GTP Daytime Running Lights
    By techweenie in forum Audio, Security & Visual Electronics
    Last Post: 05-05-2010, 06:39 AM
  5. A/C and Daytime running lights
    By hydrashok158 in forum General Tech Discussion
    Last Post: 08-14-2009, 09:06 AM
