Thread: STILL problems... lost for solutions
Results 1 to 14 of 14
  1. #1 STILL problems... lost for solutions
    figured id just make a new thread instead of updating the old one...
    so as the old one said ill be driving around and my fuel trims will peg at 16.4 and my WB will read around 10.5... the only way I can get my trims out of 16.4 and everything back to normal is to give it alot of gas
    now, after reading some I figured it was the EVAP system...
    so I unplugged the cable to my cannister and unplugged it from the purge under the hood...
    still no changes...
    any ideas here?
    thanx,
    jarred
  2. #2 Re: STILL problems... lost for solutions
    Florida
    Data log and bin file please?
  3. #3 Re: STILL problems... lost for solutions
    I have an issue with starting a new thread because you haven't solved a problem.
    My issue is.. we are supposed to ask you again for all the info and then resuggest the same stuff? Sorry, but I'm going to sit this one out.
  4. #4 Re: STILL problems... lost for solutions
    Texas
    You more than likely have a vac leak. Spray the engine with carb cleaning.
    The biggies that are usually cracked and hidden are the ones behind the battery(there is a T there). Also pull your front bumper cover and check the vacuum canister on the driver side by the wheel.
    85 Corvette
    01 TA
    03 Z06
  5. #5 Re: STILL problems... lost for solutions
    Ill spray it again and check the cannister... how do I upload a bin/scan on here?
  6. #6 Re: STILL problems... lost for solutions
    Charles City, IA
    What year is your car and do you have a cat?
    SMGPFC Two Nipple General
  7. #7 Re: STILL problems... lost for solutions
    02 and no
  8. #8 Re: STILL problems... lost for solutions
    Charles City, IA
    Thats probably your issue.
  9. #9 Re: STILL problems... lost for solutions
    its not the 02 code thing....
  10. #10 Re: STILL problems... lost for solutions
    Quote Originally Posted by gtpsleeper View Post
    I'd be willing to bet it is...
  11. #11 Re: STILL problems... lost for solutions
    Florida
    You can save them in a zip file and pm them. Also scandepot.com has been used for a while to post scans.
  12. #12 Re: STILL problems... lost for solutions
    The 02 code has different symptoms though.... And its been deleted for almost 3 years now and has never had problems...
  13. #13 Re: STILL problems... lost for solutions
    Quincy, Mass
    when fuel trims pin to 16.4 its 9 times out of 10 a vac leak. i didnt read through your other post. did route your vac lines properly?
    No more GP 04 Impala SS Indy:
  14. #14 Re: STILL problems... lost for solutions
    OK...
    so after many days of spraying vac lines and many different checks I figured it out...
    when I sprayed the #6 cylinder with some cleaner it sputtered and the gauge said 10-20 misfires as i spray it....
    so now my question is how can I get it to seal up?
    I took it out and put it back on with no change...
    bad O rings maybe?
  1. im lost!
    By adamLG in forum General Tech Discussion
    Last Post: 06-21-2011, 05:39 AM
  2. lost mpg
    By angie in forum General Tech Discussion
    Last Post: 12-20-2010, 10:59 PM
  3. Any Great Window Cleaning Solutions???
    By MistyChameleon in forum Visual/Body Modifications
    Last Post: 07-07-2010, 09:54 PM
  4. car lost 4th
    By Joe m in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2010, 10:08 PM
  5. I'm new! And lost!!
    By lindzabu in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2008, 07:32 PM
