Thread: L67 help
Results 1 to 9 of 9
  1. #1 L67 help
    Jul 2011
    newton falls oh
    Is the heads in my 97 Gtp aluminum and I was told from a few poeple that the studs brake off a lot when u try taking ur manifolds off any one have that problem
  2. #2 Re: L67 help
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    no they are not aluminum, and yes, sometimes mani bolts can break. soak the sh*t out of them w pb blaster!
  3. #3 Re: L67 help
    Jul 2011
    newton falls oh
    Did any of the come with aluminum heads cuz my buddie works at a junk yard and said he got one in with aluminum heads and he could get them for like 300 but I didn't no if they even came like that its sapose to be 2000 if that matters
  4. #4 Re: L67 help
    nope they never came with alluminum heads.
  5. #5 Re: L67 help
    Charles City, IA
    3.1 and 3.4 had aluminum heads.
    SMGPFC Two Nipple General
  6. #6 Re: L67 help
    Texas
    3.8 were all cast iron and yes expect the studs to break when uninstalling even with PB blaster etc. When they do drill them out and just replace them with a nut and bolt. Had to do that on my 97.
    85 Corvette
    01 TA
    03 Z06
  7. #7 Re: L67 help
    Jul 2011
    newton falls oh
    how do i get to the back to drill whats the best way to do it
  8. #8 Re: L67 help
    Texas
    Quote Originally Posted by ryanmjw View Post
    Just drill through the front facing the firewall. If you can't get it then you will have to remove the manifold. Theres also a nut welded on to the manifold(backside) where the crossover meets. So you will have to drill through that.
    85 Corvette
    01 TA
    03 Z06
  9. #9 Re: L67 help
    GT Level Member sic6's Avatar
    san marcos, tx
    Hopefully they won't break. If they do i found the fastest way is to weld a nut at the end of the bolt. It comes out much easier that way.
    97 GTP
l67
