Thread: Cam Install
Results 1 to 13 of 13
  1. #1 Cam Install
    Donating Users lflylow's Avatar
    Yakima, WA
    I have a extra engine for my GP I want to put a S1X cam in it along with some other things. I have never torn a motor down that far closest I got was a LIM gasket, I need to know what tools I need and where to get them from, plus any tips would be greatly appreciated. Small build list.
    s1x
    Ported SC & TB
    105 springs
    1.6 RR
    New timing chain (stock is good? or should i upgrade to single rollmaster)
    probably forgetting some stuff but that's the list so far.
    2000 GTP, retro's, Debadged, 15% Tint, SD headers, TB HAI, EGR delete,
    Tuned By Reptile, WBS Perf. LCA's, GMPP rear sway bar Dorman front, Tinted tails.
  2. #2 Re: Cam Install
    Omaha, NE
    You can tear a 3800 apart with a standard mechanics tool set and a breaker bar.
  3. #3 Re: Cam Install
    New stock.
  4. #4 Re: Cam Install
    Charles City, IA
    Need some torx bits, and a 24mm or 1.25" socket for the cam bolt.
    SMGPFC Two Nipple General
  5. #5 Re: Cam Install
    Yakima, WA
    awesome no special tools. Hopefully have that engine and a TEP transmission in the car by next summer.
  6. #6 Re: Cam Install
    Yakima, WA
    should i get OE R lifters and some new push rods or leave them alone?
    Also with the motor just being an extra time is not an issue should I yank the heads off and get a light port job or is that pointless for the s1x since its designed to run with stock heads?
  7. #7 Re: Cam Install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by lflylow View Post
    Leave pushrods alone. If you want lifters, get the LS7 ones. Porting the heads will help, but it's not necessary. If you're thinking of doing it, do it, so you don't have to tear it all down again.
  8. #8 Re: Cam Install
    Jersey
    front cover gasket, new cam bolt, stock chain and fresh tensioner, and just lube the new cam to hell with red cam lube and or mobile 1
    all can be done with your basic hand tools, torque wrench, torx bits, and a cheap angle meter
    16' wrx sti- stock
  9. #9 Re: Cam Install
    Yakima, WA
    Are the only 1.6 Roller rockers available the yella terra's?
    I have repeatedly googled the HS 1.6 but don't find them being sold anywhere also not listed on intense website.
    I found this Comp cams part #1105-12 I believe its for a L67?
  10. #10 Re: Cam Install
    For the cost, I'm not quite sure the gains are worth it.
  11. #11 Re: Cam Install
    Yakima, WA
    so just stick to stock Rockers Lifters and pushrods, change the cam and springs and call it a day?
    Mostly I was changing all that to get the most reliable power I could.
  12. #12 Re: Cam Install
    get new stock lifters.
    Aka LS7 OEM lifters.
    $130 seems to be the going rate for a set of 16.
    So, cam, lifters, springs, retainers, valve seals, and some sort of freshened timing chain.
    S1X.... definately new stock chain and new tensioner.
  13. #13 Re: Cam Install
    Yakima, WA
    Yea u can get a set of 12 from Texas speed for 98.00.
    New list
    Ported sc&tb
    LS7 lifters
    105# springs
    Retainers
    Valve seals
    new gm timing chain & tensioner
  1. Help with HID Install
    By trenaro in forum Visual/Body Modifications
    Last Post: 03-23-2011, 12:04 PM
  2. cam install
    By Juanmiguel in forum The Rant Forum
    Last Post: 01-12-2011, 07:57 PM
  3. Gen V Install
    By BoostnBlackGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2010, 09:04 PM
  4. vs cam install
    By Silver GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2010, 04:09 PM
  5. Do I need a cam kit to install a VS cam
    By ncccgolf5 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 02:51 AM
