theres a TPS relearn that you can do. i think its with car off but in the run position, you put the gas pedal to the floor 3 times in a row and that does it. you should search for it though because im not positive thats the procedure.
the other thing, is you hood hitting the cable bracket when you close the hood? when the bracket goes up it might be hitting the hood and getting stuck. you can bend the bracket a little and then adjust your cables again or take the pad off the hood to give you more clearance.
