Thread: trunk leak
Results 1 to 6 of 6
tcafego trunk leak 09-04-2011, 10:12 AM
tcafego Re: trunk leak 09-04-2011, 10:13 AM
DreadMcLaren Re: trunk leak 09-04-2011, 10:13 AM
Mad Monkey Re: trunk leak 09-04-2011, 10:14 AM
tcafego Re: trunk leak 09-04-2011, 10:21 AM
Mad Monkey Re: trunk leak 09-04-2011, 10:32 AM
  1. #1 trunk leak
    SE Level Member tcafego's Avatar
    Aug 2011
    taylor, mi
    So why is there a leak around the spare in the trunk?
  2. #2 Re: trunk leak
    Aug 2011
    taylor, mi
    * a lake
  3. #3 Re: trunk leak
    St. Cloud, MN
    Probably rust.
  4. #4 Re: trunk leak
    London Ont, Canada
    if you have a lake around your spare, that means water got into your trunk, and came to rest in the well.. there are drain plugs if ya want to get it outta there.. but you need to address the leaking isuse, the seal that goes around the trunk opening is the first issue, replace it.
  5. #5 Re: trunk leak
    Aug 2011
    taylor, mi
    Where are the drain plugs located
  6. #6 Re: trunk leak
    London Ont, Canada
    its easies to crawl under the car and pop it out that way, just use a flathead.. they can be a PITA to get back in sometimes.
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  3. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
  4. trunk water leak
    By abweiss in forum General Tech Discussion
    Last Post: 11-25-2009, 08:28 AM
  5. Trunk Leak
    By GPSims39 in forum General Tech Discussion
    Last Post: 07-02-2009, 11:59 PM
