Thread: coolant elbow broken inside engine
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    They are the same as dorman. I ordered them through my local o'reilly auto and installed them. They are awesome, and should resist warpage. Its worth while to get them.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  2. #22 Re: coolant elbow broken inside engine
    Apr 2011
    Elk Rapids, Michigan
    The aluminum elbows from ZZP are the same as the ones made by Dorman. You can get them from O Reilly's Auto Parts for about $12. They're the same part # as the plastic ones but with I think HP on the end of it. They had to order mine but they came in the next day They work great. They're a lot tougher. You'd have to work hard to break them. I put them in a couple of weeks ago when I did LIM gaskets and a new upper intake and have had no leaks at all.
  3. #23 Re: coolant elbow broken inside engine
    just so everyone got this clear, dorman makes them, everyone else is selling the dorman elbows, even zzp, rock auto O Reilly's and so on.
    the way zzp lists them, they make it sound like they just came up with this new parts on their own, and then over charge for them.
  4. #24 Re: coolant elbow broken inside engine
    Feb 2013
    Racine Wi
    My elbow snapped off on both ends. I took a 1/4" hex head bolt about 3" long an inserted the head inside the broken tube and snagged the inside edge and yanked with a vice grip. Both pulled out with zero effort, no need to pick.
  5. #25 Re: coolant elbow broken inside engine
    I use a blind hole pilot bearing tool. Sounds like a similar result.
  6. #26 Re: coolant elbow broken inside engine
    Iowa City, IA
    A paint can opener works well for getting the broken piece out.
    https://www.google.com/search?q=pain...IMej2QWUmIDoDg
  7. #27 Re: coolant elbow broken inside engine
    SE Level Member The Chad's Avatar
    Harrisburg, PA
    That paint can opener idea is smart! That would work great. I used screwdrivers and prayer to get mine out (when I replaced my LIM gasket). Prayer works!!!
  8. #28 Re: coolant elbow broken inside engine
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Quote Originally Posted by ExLimey View Post
    When you get the new elbows, get the aluminum ones from Dorman. I got mine at OReilly's for about $12. They're much better than the plastic ones.
    alot of places are out and its 3 months of back ordering i got mine on ebay 12 bucks less then a week
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  1. Bad coolant elbow
    By Shoggy24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 06:11 PM
  2. Coolant Elbow...AGAIN!!!
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2011, 06:32 PM
  3. coolant elbow leak again
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-06-2011, 10:33 PM
  4. coolant elbow broken, will not come out.
    By kingfish in forum General Tech Discussion
    Last Post: 02-26-2010, 08:17 PM
  5. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
