I have been trying to fix this problem for a long time now and I am stumped. Main thing is I am only getting 25-30 psi fuel pressure at the fuel rails and I am getting a flashing SES light with the 0300 code so I am not driving this car, but it is my only vehicle!
I want EVERYONES input because I am lost now. I have been checking everything I can and replacing a bunch also. I will tell you I was having this problem before I started replacing parts: I have replaced the Fuel filter, Spark plug wires (they needed it anyways), both fuel pump relays under the hood plus the fuel pump fuse, Installed PRJ fuel rails, Fuel pressure module, and there might be more but I can not think of it right now.
Before my mods with the fuel system are 42lb flow matched injectors from ZZP, Walbro fuel pump in the RaceTronix rewire kit. I already checked for vacuum leaks (fixed the SC gasket leak), and I can jump the relay to get power to the pump at all times but the fuel pressure still stays at 30 psi.
Could it be the pressure sensor on top of the fuel pump assembly?
Anyone take volt or ohm reading from there car for me to compare them to?
I need to get this car going and the mechanic I usually take my car to is booked up for weeks so he can not help me. Thanks.
