Thread: Connection of Manual Oil Pressure Gauge
Results 1 to 9 of 9
  1. #1 Connection of Manual Oil Pressure Gauge
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    How do you connect a manual Oil Pressure Gauge I want to go with the Cobalt autometer gauge and I just do not have to money to get the Electric one
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: Connection of Manual Oil Pressure Gauge
    Apr 2008
    Chillin at the Beach , VA
    Should be able to put it in where the factory oil sending unit is at. Not sure where it's located. Probably will have to use a adapter. If you have a manual, you should be able to find its location in there. If not let me know and if nobody else can give you the location, i'll look in mine and let you know.
  3. #3 Re: Connection of Manual Oil Pressure Gauge
    GTX Level Member webracin's Avatar
    Arkansas
    There is a plate that holds the oil filter. On that plate you will find the oil sending unit for the stock system. You can remove the stock sending unit and replace with a sending unit for your guage, OR, get a gasket for the plate, remove the plate and drill and tap a hole next to the original sending unit. You will need a 45 deg elbow so that the sender does not hit the CV axle, but I have been runing mine for over 5 years with no problems.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  4. #4 Re: Connection of Manual Oil Pressure Gauge
    Feb 2008
    The oil pressure sending unit is located next to, and a bit higher than, the oil filter on the back side of the oil filter adapter. It's easy to get to with the right front jacked up and the wheels turned to the left, or with the passenger front off. Most likely, you will have to use an adapter because our sending unit uses a different size/pitch hole than most gauges. There should be a small assortment of adapters that come with the gauge, however.
    EDIT: It took me 4 minutes to write this??? Dang, Chris, you beat me to it... lol
  5. #5 Re: Connection of Manual Oil Pressure Gauge
    Naugatuck CT
    Thanks for all that and one more question is it better to go with a short sweep electric or a Manual because there is not much differance between them two in price
  6. #6 Re: Connection of Manual Oil Pressure Gauge
    Arkansas
    I went with the elect one, If you have a manual and the line breaks or melts or gets cut, your SOL...with a Elect one you just loose the guage.
    webracin
    2001 Grand Prix GTP
  7. #7 Re: Connection of Manual Oil Pressure Gauge
    Wichita, KS
    Quote Originally Posted by webracin View Post
    webracin
    X2
    Ever try to clean up spilled engine oil off carpet? Fail.
    Electric is a nice investment, and worth the money. I would say save up, and spend more, and live worry free. The electric one is pretty idiot proof to wire in. One sender wire, a 12v power light source and a ground, done.
    ~F~
  8. #8 Re: Connection of Manual Oil Pressure Gauge
    Naugatuck CT
    Yea I think that I am going to go with the short sweep electric they are almost the same price as the Mechanical ones and there is no chance of messing up my sweet interior. THanks for the help everyone
  9. #9 Re: Connection of Manual Oil Pressure Gauge
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    I got an auto meter mechanical guage for mine and the included fitting worked perfect and I never had any melting or cutting issues... I ran it for a year or so until I sold the pod and guages. It was only $35... Just be aware of where you are running the line...
    2004 White GTP...Stock Stock Stock...Soon...3.0 ZZP MPS, ported blower, Pacesetter Coated Headers, FWI, Tuned PCM, VS cam, 105# springs, JP timing chain, whisper resonator and custom exhaust...My next goal(after I rebuild my savings)... 2.5" IC, 2.6 pulley, XPZ Cam, S3 heads, and a tranny....
  1. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  2. how to use a fuel pressure gauge?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2008, 01:06 PM
  3. Manual shifting
    By JCG's-GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-01-2008, 10:47 PM
  4. anyone have a Prosport fuel pressure gauge?
    By fst in forum PCM Tuning
    Last Post: 04-02-2008, 06:38 AM
