Thread: stupid question 1st gear boost
Results 1 to 12 of 12
  1. #1 stupid question 1st gear boost
    Jul 2010
    canada
    I have a 2002 Pontiac 3800 supercharged with a 3.5" pulley
    no boost works perfect. Under boost in 1st gear car is like it hits rev limiter kinda feeling
    Does the computer pull back the timing ? limit ignition or something in 1st gear?
    Once I hit second lots of boost lots of power all happiness
  2. #2 Re: stupid question 1st gear boost
    Any other mods besides the 3.5"
    Probably isn't the safest setup out there for a totally stock car...
    Also...any CEL's? Sure there isn't a vacuum leak? Or maybe it is knocking that bad it's pulling tons of timing? LOL
  3. #3 Re: stupid question 1st gear boost
    St. Louis
    Quote Originally Posted by boostman View Post
    I had a 2002 Pontiac 3800 supercharged with a 3.5" pulley
    Fixed
    I agree w/ blue. Without knowing what your flow mods are (if any) then it's probabaly pulling timing to try and keep you from posting about blowing up your motor. Give us some more info on what else you have and lets see what we can do to help.
  4. #4 Re: stupid question 1st gear boost
    Jul 2010
    canada
    Okay I'll make it more complicated I have this engine in a Fiero with a 5 speed manual ...cone air filter and 2.5" exhaust with a reprogrammed ECM
  5. #5 Re: stupid question 1st gear boost
    Charles City, IA
    We need a scan to see whats going on.
    SMGPFC Two Nipple General
  6. #6 Re: stupid question 1st gear boost
    Jul 2010
    canada
    well has no DTC's through all this. Buddy has a scanner can't figure out how to read the KR and stuff on it
    I'll try to get you all more info after the weekend
  7. #7 Re: stupid question 1st gear boost
    Charles City, IA
    I mean a scan with boost psi, wideband afr, timing, injector duty cycle, ignition retard, rpm ect.
  8. #8 Re: stupid question 1st gear boost
    You didn't make things more complicated at all. You helped us a lot. By knowing your setup etc. We can help/diagnose better.
    It does sound potentially like KR to me as well. Wouldn't be torque management if you are a manual trans, so it could be actual knock.
    What brand and version of plugs and wires are you running?
  9. #9 Re: stupid question 1st gear boost
    Jul 2010
    canada
    Okay thanks all for the replies got it all legal now and on pavement does the ddddd thing at 4 grand in second under boost so probably all the time
    Oh yeah really wants to stall when I come to a stop
    Seems like ignition to me ohm 'ed the coils at the coil ends 6.6 for all 3 the spec i found says 5-8 so probably good wires seem good
    okay the plugs that are in it are NGK TR551GP not stock plugs are these right for my combo 3.5" blower pulley 2.5" exhaust cone filter
    Ive read lots that plugs make a big difference.
  10. #10 Re: stupid question 1st gear boost
    Huh.
    Smaller pulley.
    No exhaust mods other than I'm assuming catback and that doesn't help at all.
    Have you pulled the plugs to see if you still have electrodes left?
  11. #11 Re: stupid question 1st gear boost
    utah
    Who "reprogrammed" the ecu?
  12. #12 Re: stupid question 1st gear boost
    Jul 2010
    canada
    yeah pulled all the plugs all good now (one was cracked presumably from engine installation) to do a compression test bad LIM gasket
    Are the plugs right for my combo?
    I don't know who reprogrammed the ECU it is the right one for the motor but converted for the Fiero bought the project in the middle got it all going now now working on the debugging luck to me
  1. stupid question?
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2011, 11:13 AM
  2. Stupid Question but ill ask any way
    By protoplayer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2011, 12:15 AM
  3. Here is a stupid question
    By tgarison in forum Off Topic Discussion
    Last Post: 06-03-2011, 01:56 AM
  4. I got a stupid question...
    By sparty16 in forum General Tech Discussion
    Last Post: 04-21-2011, 12:19 AM
  5. Stupid Question
    By Tyler_06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-24-2009, 01:23 AM
