i take the picture because then you know. Looks like you are going back into the timing cover.
A trick you can use is line up the crank with the original gear and then line things up with your new gear and put your old gear on after to see that it's lined up.
There's just so many different ways a guy could install the gear that it makes it confusing. Here is a rollmaster double installed for reference
