Doubt the ground is an issue.
It's not one bolt higher though. It's one bolt further from the engine. Look down at your lowest trans to engine bolt. Should have a stud on teh end. That's where the grounds go. You should have two loops plus the battery cable. On the starter you should have two sets of wires going to single loops and the battery cable.
If any of this is wrong, you could have starting issues.
