Thread: Engine wont start
Results 1 to 20 of 110
  1. #1 Re: Engine wont start
    SE Level Member Hixc's Avatar
    Lawrence MA
    My coolant temp sensor wire is disconnected, does that matter? We can't find the wire on the harness to plug it in. Doesn't make sense to me
    S1X, TOG, Trannyman Gen3, 3.0/2.8, 42.5#, 105#, Thrasher, Borla PRO XS, Magnaflow Cat, 1.6 roller rocker
  2. #2 Re: Engine wont start
    you check the crank and cam sensors? put them back on right? are they new or old, did you clean them up real good if old? and clean the HB back side?
    and im not sure of the torque on the rocker bolts, 11 sounds low, but it should have still started even if the rockers were clapping all over the place.
    coolant temp sensor shouldn't matter.
    seems like a bad sensor or down them lines.
  1. wont start
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2011, 01:56 AM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. rough engine then wont start
    By RyanL in forum General Tech Discussion
    Last Post: 06-06-2010, 03:32 AM
  4. 93 with 3.1 wont start!
    By rvdavis in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-02-2009, 05:27 PM
  5. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
