alright here is the lowdown- 06 L32 gen V, xp cam, modified intense stage 2 heads fresh back from the machine shop. new si valves, valve job, new guides seals etc,(installed height correct) new LS7 lifters, new comp pushrods, cometic .052 head gaskets, new comp 105 springs(shimmed to exacly 105lbs), new retainers, locks.
Checked preload just cuz of head machining, thin gaskets etc. Preload good with betw 1 and 1.25 turns. (correct length pushrods now) also measured w dial indicator. all good. Checked oiling to heads-flows good. assembled with cam/lifter prelube. went thru all bs "break in" crap.
i have a mysterious "tap" coming from the front bank of cylinders in the vicinity of cylinder 5. Its def not a lifter tick, not a knock.
i can only describe it as a tap.
I had it runnin with the valve cvr off, oiling is good, nothin funny goin on. even swapped out the rockers with another set i have just to be sure its not them. Swapped the pushrods from cyl 5 to 1.
NO change.... everything looks and assembled perfectly.
Cant hear it at idle, only between 1500 and 2000rpms. very distinct noise then.
I am at a loss on what it may be. Need to get the car tuned and dont want to till i know its not gonna blow up! HELP!
