Thread: knock sensor
Results 1 to 6 of 6
  1. #1 knock sensor
    Banned
    Jun 2011
    is the plastic part of the knock sensor supposed to wiggle at all?
  2. #2 Re: knock sensor
    Ummm, not that I can recall.
    Front or rear one? Because the front one can be done while the motor and trans are in the car...the rear...one or the other has to come out...
  3. #3 Re: knock sensor
    May 2011
    Bremen,GA
    I just replaced mine last month,was having KR issues and figured why not.
    The plastic plug on my sensor was somewhat flexible,but you could tell they were aging due to the seal being worn. You really shouldn't have much movement between the plastic and metal sensor body,but I've watched people use salvaged sensors that tested good and "wiggled" almost like jello,(exaggerated). If in doubt,try a new set,torque at 14 foot lbs.
  4. #4 Re: knock sensor
    It shoudl not wiggle. And you can get the rear w/o pulling anything..but it's not fun.
    Remember to torque to 14ft lbs as the sensitivity is based on torque
  5. #5 Re: knock sensor
    Banned
    Jun 2011
    i didnt think it should wiggle..14 ft lbs, got it. thanks
  6. #6 Re: knock sensor
    I should have said sensitivity relies on the correct torque value. Otherwise it may be over/under sensitive.
  1. knock sensor location?
    By quickster in forum General Tech Discussion
    Last Post: 03-22-2011, 12:10 AM
  2. Rear Knock Sensor
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-16-2010, 04:05 PM
  3. knock sensor problem??
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2010, 02:26 PM
  4. Knock Sensor
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 01:51 PM
  5. knock sensor?
    Last Post: 10-20-2008, 12:19 AM
