Thread: Bent plug tips and misfires
Results 21 to 40 of 63
  1. #21 re: Bent plug tips and misfires
    GT Level Member Knightmare's Avatar
    Jul 2011
    Frederica, DE
    Ok..so....an update......my battery is currently charging....did compression test on four of the six cylinders...3 has no compression at all....the gauge just twitches...every other one has checked out fine...gonna go back out in a bit and finish the test....
  2. #22 re: Bent plug tips and misfires
    no compression is not good. it looks like its time to start shopping for a new block.
  3. #23 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    Ok..another small update....checked two and four.....they are weaker than one and five..but are leaps and bounds better than three.....it has a pretty good oil leak from the back valve covers....don't know if that would have anything to do with it....
  4. #24 re: Bent plug tips and misfires
    you chipped your pistons, its over johnny...
    when you have smashed spark plugs 9 times out of 10 you lost a piston. in your case maybe 3 pistons.
  5. #25 re: Bent plug tips and misfires
    Charles City, IA
    yup number 3 is gone, pull the heads off and learn how to take these cars apart and take pcis for us then get another engine.
    SMGPFC Two Nipple General
  6. #26 re: Bent plug tips and misfires
    Jul 2011
    Edmonton, AB
    Leaky valve cover would have nothin to do with no compression.. Time to look for a used engine...
  7. #27 re: Bent plug tips and misfires
    Texas
    Quote Originally Posted by txslow6 View Post
    Every plug that I have seen on a GP like that has been a chipped piston. Who knows maybe you will be the first that didn't with a plug looking like that.
    Good luck
    Guess you weren't the first.
    85 Corvette
    01 TA
    03 Z06
  8. #28 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    Guess ill start lookin for block.....anyone know where i can find one? Lol
  9. #29 re: Bent plug tips and misfires
    i'd start with your local junk yards, to avoid shipping, not sure where your from.
  10. #30 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    Im in Delaware scotty...started out lookin around here
  11. #31 re: Bent plug tips and misfires
    SWPA
    I had plugs that looked like that once. My TSI leaned out hardcore and melted them.
    I lucked out and "only" fried the rings.
  12. #32 re: Bent plug tips and misfires
    Quote Originally Posted by Knightmare View Post
    if you cant find a s/c engine you could get a n/a block and top swap it with your cars parts, if your heads are still ok. you would need a tune then.
  13. #33 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    I had pistons that looked like that once. My TSI leaned out hardcore.
    wow...that sucks...I'm on the hunt for a new block now..once I find one..I'll take this one apart for a rebuild..if i have the money...plus it'll give me a chance to learn more lol
  14. #34 re: Bent plug tips and misfires
    SWPA
    I was reading as I was typing and meant to say I had plugs that looked like that once. LMAO.
    You know what I meant though.
  15. #35 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    thanks scotty.I'll have to look into it...I wouldnt be able to just use the stock gtp pcm? just curious lol
    @stealthee
    yea..I knew what ya meant
  16. #36 re: Bent plug tips and misfires
    @stealthee
    you would have to have your stock pcm re tuned.
    may even look into a cam and headers while its out and apart, if you dont have any goodies yet
  17. #37 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    Ok..so i might have a regular 3.8 lined up for 200-250....wont know for sure until Monday...began teardown of original motor tonight..but due o my limited experiance..was only able to get the supercharger off.....but i will be working on it more tomorrow hopefully....guess ill try a topswap.....and retune lol
  18. #38 re: Bent plug tips and misfires
    take lots of pics, vac lines and anything you may forget where it went in 2 or 3 days lol. bag and tag bolts and wires, just keep it organized and you'll be ok.
  19. #39 re: Bent plug tips and misfires
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Perfect time for a top swap!
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  20. #40 re: Bent plug tips and misfires
    Quote Originally Posted by torq455 View Post
    well in his case a bottom swap. hes s/c but cant seem to find anything but a n/a locally. with a side of luck his heads held up, most of the time the valves don't like passing metal chunks.
  1. Misfires in Cyl 4
    By mousemonster1232 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2011, 02:38 PM
  2. Spark Plug tips gone!!! UPDATE 2/6/2011
    By MidnightBlue in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2011, 09:22 AM
  3. Bent rim
    By dengnath in forum Tires & Wheels
    Last Post: 01-07-2011, 08:19 PM
  4. Mandrel Bent Pipes vs. Regular Bent - New Exhaust
    By roundbox52 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 10:46 AM
  5. WOT misfires
    Last Post: 11-12-2008, 08:58 PM
