Thread: Intake not Sucking air gtp
Results 1 to 20 of 32
  1. #1 Intake not Sucking air gtp
    Donating Users kyleinkman's Avatar
    May 2011
    canada
    Hey so my 03 gtp has starting acting up today, My CAI is barely sucking air at all and my gas milage has died aswell. Ive cleaned the MAF and got rid of the carbon in the intake already. even with the K&N un attached it is still sucking little to no air.. Ive checked all the vacuum lines i can see but im open to check again if theres one you guys suggest im failing to see. Does anyone have any idea what could have caused this? was working great yesterday thanks in advance.
  2. #2 Re: Intake not Sucking air gtp
    clogged cat? is the car gut less as well? like no power.
  3. #3 Re: Intake not Sucking air gtp
    May 2011
    canada
    cats not clogged its only about 2 months old, it has power but a sig loss since yesterday
  4. #4 Re: Intake not Sucking air gtp
    have you tried spraying some carb cleaner around the engine yet, if the idle jumps, you have a vac leak.
  5. #5 Re: Intake not Sucking air gtp
    May 2011
    canada
    yeah i did that when i cleaned the maf. is there any significant hoses for the Intake that i should double check? also would this be my supercharger going?
  6. #6 Re: Intake not Sucking air gtp
    one of the more common ones is under the sc snout, the one with the T fitting.
    i dont think your sc is going bad, something else is going on.
  7. #7 Re: Intake not Sucking air gtp
    Pennsylvania
    Air's got to be getting in somewhere for the engine to run. Look for a big-ass hole. You can't miss it.
    Is your supercharger belt off?
  8. #8 Re: Intake not Sucking air gtp
    May 2011
    canada
    sc belt is on, the one with the t fitting with the harder hoses?
  9. #9 Re: Intake not Sucking air gtp
    May 2011
    canada
    boost control is not holding the butterfly keeps dropping should the pintel stay up or should it drop down to hold boost or should it drop to release the boost?
    also oil is leaking slowly from the base of the snout could the upper intake gasket failing cause this? belt isnt loose or slipping. i have an fuel system lean bank 1 code. no other codes.
  10. #10 Re: Intake not Sucking air gtp
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    Only advice i can give is get some carb spray... Spray around and wait for the idle to trickle up and down find the leak
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  11. #11 Re: Intake not Sucking air gtp
    vaccccc leaks......
    oil might be the snout fluid.
    cant tell without looking at it.
  12. #12 Re: Intake not Sucking air gtp
    Grand Island, Nebraska
    Supercharger oil will only leak from the snout fill plug, the plug thats on the end of the pulley, and the seal between the snout and the case.
  13. #13 Re: Intake not Sucking air gtp
    it leaks from the snout seal at the pulley, the seals in the rotor pack, rotor pack plate and s.c case as well.
    leaks anywhere it wants really.
  14. #14 Re: Intake not Sucking air gtp
    I should not have used the word "only"
  15. #15 Re: Intake not Sucking air gtp
    System 1 Bank Lean is a vacuum leak.
    Find it.
  16. #16 Re: Intake not Sucking air gtp
    Jan 2009
    Tallahassee, FL
    How's your PCV valve? Could oil from the blower mean a bad seal? That could be the source of the vac leak.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  17. #17 Re: Intake not Sucking air gtp
    PCV though when toast most of the time squeals really loud...
  18. #18 Re: Intake not Sucking air gtp
    May 2011
    canada
    so far today i have changed the fuel filter. problem still persists this vacuum leak is being very difficult to find. I guess my next option is carb cleaner and a camera.. maybe you guys will hear somthing im missing
  19. #19 Re: Intake not Sucking air gtp
    Jan 2009
    Tallahassee, FL
    I have to ask, gas cap?
    77 Morris Garage B
  20. #20 Re: Intake not Sucking air gtp
    ^^Pretty sure that'd be tossing an EVAP...not a Bank 1 lean...
  1. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  2. Air Intake
    By JAMIEPERRY86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2011, 06:06 PM
  3. 3.1L Intake
    By josemolina2008 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-26-2009, 02:32 PM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
