What is the electrical sensor for? on the intake manifold sorta underneath the thermostat housing on a 2002 supercharged 3.8
I believe that is the coolant temp sensor.
Its your coolant sensor
Is there another coolant temp sensor on the motor? or one with the same plug? car runs rich BUT
I have it in a fiero with a harness somebody made so I'm twice confused i have everything plugged in but this sensor seems extra
Edit okay I understand on my 2002 3.8sc intake coolant temp sensor there is a PATCH harness to convert the oval connector to flat style connector I had an AHA moment solved two problems
just in case someone here runs into this problem
