Thread: working on my GTP
Results 1 to 5 of 5
  1. #1 working on my GTP
    GT Level Member Knightmare's Avatar
    Jul 2011
    Frederica, DE
    hi all..hopefully someone can help me out...my father and I were working on my GTP and I noticed some liquid under the supercharger..can someone maybe tell me what it is..and maybe why it's there? here is a pic, the fluid in lying in the circled area:
  2. #2 Re: working on my GTP
    HUDSON
    It is probably engine coolant from the defective factory intake manifold gaskets,
    If the Lower Intake Manifold gaskets have not been changed, change them now before they realease coolant into the engine intake ports or inside the cranckcase.
  3. #3 Re: working on my GTP
    Sorry.. Intake gaskets don't cause fluid there.
    That's one of three things.
    1. Seepage. Seepage in that area is caused by the LIM bolt no longer sealing. These bolts go into areas that have oil return or coolant passages in the head. Seepage is slow and not something I would say is a big concern unless you clean the area and it fills quickly.
    2. Dirt, grime and water. Dirt and grime gets all over. Add a little potential water from washing etc and it can look nasty.
    3. Valve cover seepage. Our gaskets and grommets wear out and cause seepage/leaks. While it's less likely for the VC gasket to seep up here, it's possible and oil does splash around when the motor is running.
    I'd suggest cleaning it down. Whether you are looking to go in for intake/valve cover gaskets soon or just want to keep an eye on the potential leak, it's good to clean it down. Then keep an eye out as to what is going on and where it's coming from. That way if a repair is needed, you can do the repair that fixes the item causing the leak. Mechanics sometimes misdiagnose a leak because they don't have the ability to clean and then spend a week or more looking to see where the leak is coming from.
  4. #4 Re: working on my GTP
    HUDSON
    My gaskets were leaking there, have photos.
  5. #5 Re: working on my GTP
    Jul 2011
    Frederica, DE
    thanks guys I will try to clean it up and see what happens from there....just a lil backstory...the guy I bought it from said he had a clogged cat...then he took it to his mechanic who said the heat from the clogged cat caused two of the pistons to seize up....but the car still ran..just kinda rough...but I changed the spark plugs..because half of them shouldnt have even been firing from how they looked....and it seemed to do a lot better..not perfect but it made a huge difference
  1. Working alone...
    By MrPoopyButthole in forum The Rant Forum
    Last Post: 05-27-2011, 06:58 AM
  2. DIC still not working...
    By zql8tr in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2010, 09:49 AM
  3. HUD not working
    By tdm571 in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2010, 09:05 PM
  4. site working and then not working etc.
    By Rocket468 in forum Site/Club News
    Last Post: 03-24-2010, 11:53 PM
  5. AC not working
    By thewaitinggame in forum General Tech Discussion
    Last Post: 06-29-2009, 12:15 PM
