Ok well when I got to the dyno it was breaking up bad on the first pull due to it running pig rich, adjusted the air fuel and started making some decent power (265 on a low reading mustang dyno. Would be around 300whp on a dyno jet) and started gettin a little spark blow out. Nothin to big though, so we pulled the plugs and gapped them closer (104s gapped at .035 just to see what would happen) and the car started missing and breaking up pretty bad at wot, so then I put in new 104s gapped at .055. Did another pull and the same thing, still missing and cutting out at wot, so put new plug wires in, and still the same outcome......I just don't get it, I was starting to make some good power and as soon as I touched the plugs, everything went down hill.....only other guess would be the coil packs or maybe the fuel filter is clogged from the e85 cleaning everything out.......
