Thread: Need help....sputtering bad
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #1 Re: Need help....sputtering bad
    Apr 2011
    central jersey
    Well I went against ur advice zef and changed the plugs out again with ngk tr55s.....the platinum tips if the 606s where completely gone after only about 150mls.....needless to say after replacing with the tr55s and driving for about 150 mls, the car is running better than ever......i guess the type type of plug has alot to do with it
  2. #2 Re: Need help....sputtering bad
    I live here. TLSheff's Avatar
    Quote Originally Posted by Drw7475 View Post
    How many times must it be said.... PLATINUM does NOT last in these engines. Iridiums is recommended by factory specs, or regular copper core autolights... NO PLATS!!!
  3. #3 Re: Need help....sputtering bad
    PA
    But didn't you read. It runs better with platinum. Had to be the choice of plugs. 606s apparently don't work in our engines.
    2001 GSE
  1. Sputtering Problem...?
    By ray4was in forum General Tech Discussion
    Last Post: 05-02-2011, 09:41 PM
  2. sputtering under load
    By Jay7199 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2011, 01:44 PM
  3. gtp sputtering
    By ecflattracker in forum General Tech Discussion
    Last Post: 03-12-2010, 11:15 AM
  4. sputtering
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 02:25 AM
  5. help. car sputtering at wot.
    By 1gtp99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 05:15 PM
