Thread: Knocking Sound in S/C Snout
Results 1 to 5 of 5
  1. #1 Knocking Sound in S/C Snout
    Destroys cars izup69's Avatar
    Iowa
    Ok I just got myself a 97 gtp with 144k on it in didn't here the knocking when i checked the car out but now I hear it at idol. It's comeing from the snout but I feel no play in the pully. So I didn't know if it would be the coupler or not it sounds like marbles rolling around. They didn't know when the s/c oil was changed so i know that has to be done. But the noise is driving me bonkers now.
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  2. #2 Re: Knocking in s/can snout
    did you take the belt off when you did this?
    im guessing its the coupler
  3. #3 Re: Knocking in s/can snout
    Charles City, IA
    sounds like a coupler.
    SMGPFC Two Nipple General
  4. #4 Re: Knocking in s/can snout
    Iowa
    No didn't take belt off just got it home lol ill take the belt off in the morning and see if there is play
  5. #5 Re: Knocking Sound in S/C Snout
    No, take off the belt and start it.
    If the sound goes away...then it is 99.99999% the coupler is toast.
    Or...in your sig it says possibly modded...maybe its a huge rod knock...lulz.
  1. knocking sound
    By casperyaj in forum General Tech Discussion
    Last Post: 03-27-2011, 08:43 PM
  2. knocking sound
    By scott1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 08:46 AM
  3. knocking sound from engine
    By BSP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 09:03 AM
  4. knocking sound
    By kenneth74gt in forum General Tech Discussion
    Last Post: 08-24-2010, 04:13 AM
  5. GTP Knocking Sound. Any Ideas?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 11:38 PM
