Thread: Loud exhaust leak!
Results 1 to 12 of 12
  1. #1 Loud exhaust leak!
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    So I decided I would go out for a cruise since I was bored. While I was cruising down the highway, I felt like doing a WOT run. So it got to about 5000rpm and then it got really loud. So I just kept coasting until I had to hit the gas again and WOW, its LOUD. My car now has a full body massager built in.
    So I went under the car and had a look and the pipe right after the u-bend disconnected from the other one. Heres a pic I found on the internet so you can see where I mean. Ignore the second picture.
    Heres what it sounds like lol: YouTube - ‪Exhaust leak lol‬‏
    Any ideas on how much this would cost to fix?
    I'm thinking this might be the perfect excuse to do the u bend delete.
  2. #2 Re: Loud exhaust leak!
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Depending on how you fix it:
    You can just have an exhaust shop weld in a straight pipe with o2 bung, no flanges, would cost at most $75
    You could have them weld pipe to the cat, then make a new flange for the one that blew out on you, that might cost alittle more.
    For all your 3800 needs:
  3. #3 Re: Loud exhaust leak!
    May 2011
    Quote Originally Posted by copgtp View Post
    are you saying just get rid of the cat entirely?
  4. #4 Re: Loud exhaust leak!
    Orange County, NY
    No, they should be able to weld a new piece of pipe right to the cat.
  5. #5 Re: Loud exhaust leak!
    May 2011
    oh ok. too bad tomorrow is sunday will i notice a hp increase without the u bend?
  6. #6 Re: Loud exhaust leak!
    Orange County, NY
    You will be able to finally do some mods without the u-bend! It's the most restrictive part of the stock system.
  7. #7 Re: Loud exhaust leak!
    May 2011
    Awesome! thanks for your help!
  8. #8 Re: Loud exhaust leak!
    May 2011
    so i went to two shops, one quoted me 200 and the other one wanted 250. and they both said i couldnt weld a pipe in place of the ubend cuz the o2 sensor would get destroyed and the pipe wouldnt fit properly on the cat?
    I dont want to spend 200 to fix this problem.
    any suggestions?
  9. #9 Re: Loud exhaust leak!
    Try more shops. Because tons and tons do it. No one bends a U to put back in place.
  10. #10 Re: Loud exhaust leak!
    You remove the o2 from the u-bend.
    Then they cut it and the cat out...because a converter is lamesauce.
    Then they weld a piece of straight pipe in there in place of them.
    Then they weld a universal bung to the side of it.
    Re-install o2 sensor.
    Done.
    If it costs more than $50...your getting hosed.
  11. #11 Re: Loud exhaust leak!
    Grand Island, Nebraska
    If the pipe didnt disconnect from the flange, your bolts could have just rusted. i.e. 3$ fix for 2 new bolts. but Its still not a bad idea to get the ubend replaced.
  12. #12 Re: Loud exhaust leak!
    SE Level Member 3R1CD4V15's Avatar
    May 2011
    Virginia
    Quote Originally Posted by cameron92 View Post
    any suggestions?
    Dont go to fix-it places like Meineke, (ext, ext...) they will charge u a f**k load to do this and the will tell u bs like thats not the "right way" to do things. Just go to a local exhaust guy that is down to earth and i garentee he will do it.
  1. loud crackly exhaust
    By jcmonteman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2011, 08:30 AM
  2. exhaust loud as hell!!
    By tmackster in forum General Tech Discussion
    Last Post: 03-27-2011, 05:46 PM
  3. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  4. exhaust leak
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 10:31 AM
  5. Need help with an exhaust leak
    By thenervemann in forum General Tech Discussion
    Last Post: 04-26-2009, 09:28 PM
