Thread: I'm lost here, please help
Results 1 to 6 of 6
  1. #1 Re: I'm lost here, please help
    Jul 2010
    Houston, Texas, United States
    Quote Originally Posted by Juanmiguel View Post
    So I still have problems with the O2 sensors:
    I first got a code and it kept coming back after a couple of days when I deleted them. I decided to buy a new duralast sensor. When I installed it, car would run like crap and on powrtuner it would read 1106 mv all the time even with the car turned off. I went and changed the sensor for another duralast and the same thing happened, so I took my money back and kept my old sensor.
    Next, I bought a Tomco O2 sensor, installed it and now I get a P0134 (not enough activity), the scanner readings are either 437 and 451 (I get the exact same readings with the sensor disconnected) I only get these two no matter how much i accelerate and with the engine turned off. The trims are also 0% all the time now.
    Problem is that now the same thing happens with my old o2 sensor, but it was reading in the 400's and wouldn't go any higher or lower except this one would read different values, not just two like the new one. On the way home just now, the old O2 sensor starting reading only 2 values also, but this time is 0 and 4 mv.
    When I have no O2 sensor connected the O2 readings are also 437 and 451 always, but I'm not sure if this is right, I thought it should read 0 mv with the sensor disconnected.
    I also tried using a different PCM and nothing changes. I tested the wires for connectivity from the sensor connector and the pcm connector with a multimeter and they seem to be ok.
    Now my question is what should the O2 reading be with the sensor disconnected? I'm not sure what to do next, should I go and get a 4th sensor and test it? Maybe a bosch one this time?
    Perhaps try a 3rd PCM?
    Denso 02 sensor from rock auto,try that since the bosch ones have a high fail rate on our cars. Most low end (readily available) 02 sensors die quick. Hope this helps.
  2. #2 Re: I'm lost here, please help
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    From what I remember, when I had the O2 sensor disconnected, it read mid 400's constantly.
  3. #3 Re: I'm lost here, please help
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Quote Originally Posted by Bedwards View Post
    Thanks for the info, that means my readings aren't wrong. I just find it hard to believe that I've got 3 defective sensors in a row. I think I'll order a Denso one from rockauto.
  1. lost mpg
    By angie in forum General Tech Discussion
    Last Post: 12-20-2010, 10:59 PM
  2. im lost here
    By sven101 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 04:07 PM
  3. car lost 4th
    By Joe m in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2010, 10:08 PM
  4. I lost :(
    By nawarkk in forum Track Sessions and Kills
    Last Post: 11-06-2009, 04:00 PM
  5. I'm new! And lost!!
    By lindzabu in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2008, 07:32 PM
