Thread: 2005 grand prix burning gas like crazy!
Results 1 to 20 of 27
  1. #1 2005 grand prix burning gas like crazy!
    georgia
    Ok so I had to put gas in the car everytime I started it up, and to make matters worst it shuts off on me. I have to crank it up 2 or 3 times before it will ide properly. went to the mechanic. He said the engine was not duplicating the ide so he fix that, since then it hasn't shut off and it was burning gas at a normal rate. But now its back to burning the gas at a rapid rate and the engine knocks heavier than normal. I plan to replace wires and plugs over the next few days see if that helps...any other ideas or imput is appreciated..thanks..
  2. #2 Re: 2005 grand prix burning gas like crazy!
    Video?
    It knocks?
    Failing engines get pretty bad MPG's...description is kinda vague though.
  3. #3 Re: 2005 grand prix burning gas like crazy!
    Fla.
    Any DTC's ,something should show out of range if it's dumping fuel in the cylinders, unless you just have one injector failing , and the ecm doesn't see any change in coil resistance,but the injector is hanging up inside, and fuel is just blasting threw it. It would be nice if you get a specific cylinder miss code, to point you in the right direction. If you think it's all the cylinders running rich, check the fuel rail pressure regulator vacuum line, maybe it's cracked or leaking, that would cause higher fuel pressure at all engine loads.
  4. #4 Re: 2005 grand prix burning gas like crazy!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    SOunds like a Fuel pressure regulator. But I agree your discription BLOWS.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: 2005 grand prix burning gas like crazy!
    georgia
    sorry guys, here is an example. i live .6 miles from walmart and if i left my house on a half of tank of gas to go walmart by the time i arrived at walmart i would have burn a whole quarter tank of gas...i have clean the throttle body and the problem went away. now new problem arise, now when i drive the car and stop (put car in park) the gas gage would just go down like the car is dumping the fuel somewhere but im not gettin a error code.. and there is no signs of any leak from the engine..
  6. #6 Re: 2005 grand prix burning gas like crazy!
    SWPA
    If you were actually burning that much fuel your exhaust would be pure black and you'd look like a diesel truck going down the road.
  7. #7 Re: 2005 grand prix burning gas like crazy!
    you would have cat codes like a mofo too.
  8. #8 Re: 2005 grand prix burning gas like crazy!
    Banned
    Apr 2011
    wv
    actually it would be pure white. unless you took the catalytic converter out.
  9. #9 Re: 2005 grand prix burning gas like crazy!
    Quote Originally Posted by L36pro View Post
    Wrong.
    Over fueling is BLACK smoke.
    Coolant being burned is WHITE smoke.
    Oil buring is BLUE smoke.
    ever see a high powered diesel before, all that black smoke is raw fuel that is un-burned.
  10. #10 Re: 2005 grand prix burning gas like crazy!
    Banned
    Apr 2011
    wv
    diesels dont have catalytic converters friend
  11. #11 Re: 2005 grand prix burning gas like crazy!
    SWPA
    No, its not. Raw fuel will burn black with or without a cat.
    Where do you come up with this stuff? Do you make it up as you go along and think no one will notice how wrong you are?
  12. #12 Re: 2005 grand prix burning gas like crazy!
    did you even read what I said?
    It dont ****ing matter if it has a cat or not, what I said is truth.
    you could have a cat converter and still be throwing black smoke out the tailpipe, the cat wont like it much and will soon clog.
  13. #13 Re: 2005 grand prix burning gas like crazy!
    Banned
    Apr 2011
    wv
    ive had my share of carb'd cars that burned black, but they all had straight pipes.
    ive never seen a modern EFI car with a cat burn black. ive seen TONS burn white.
  14. #14 Re: 2005 grand prix burning gas like crazy!
    Hagerstown,Md
    Never seen a car with black soot on the rear bumper? Look at a grand am once lmao. White smoke would be lean or coolant burning. Anyways, if you can watch the gauge go down, id assume your leaking at one of the injector O Rings or the quick connects on the rail
  15. #15 Re: 2005 grand prix burning gas like crazy!
    SWPA
    The only thing that will burn white is coolant.
  16. #16 Re: 2005 grand prix burning gas like crazy!
    Banned
    Apr 2011
    wv
    lol, grand ams and cavaliers. what a bunch of $hit boxes
  17. #17 Re: 2005 grand prix burning gas like crazy!
    Hagerstown,Md
    Run down the 1/4 at a 13.8 AFR once, You will have white/grey puffs comming out the back end....been there done that
  18. #18 Re: 2005 grand prix burning gas like crazy!
    Banned
    Apr 2011
    wv
    gpgt FTW!
  19. #19 Re: 2005 grand prix burning gas like crazy!
    gpgt FTW!
    sure he is right in a way, but you still dont understand why do you?
    He ONLY had that happen becuase his tune was way off and running 13.8 AFR.
  20. #20 Re: 2005 grand prix burning gas like crazy!
    SWPA
    Quote Originally Posted by 01gpgt01 View Post
    I had a TSI running much richer than that once. Smoke was black as black could get.
  1. 2005 grand prix oil check
    By 2005GrandPrix in forum General Tech Discussion
    Last Post: 02-05-2011, 01:24 AM
  2. crazy acting 07 grand prix
    By wide open 97 in forum General Tech Discussion
    Last Post: 02-03-2011, 09:27 PM
  3. My New 2005 Grand Prix
    By extreme in forum 04+ Specifics
    Last Post: 08-10-2009, 10:18 AM
