Thread: 2005 grand prix burning gas like crazy!
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #1 Re: 2005 grand prix burning gas like crazy!
    Banned
    Apr 2011
    wv
    gpgt FTW!
  2. #2 Re: 2005 grand prix burning gas like crazy!
    Quote Originally Posted by L36pro View Post
    gpgt FTW!
    sure he is right in a way, but you still dont understand why do you?
    He ONLY had that happen becuase his tune was way off and running 13.8 AFR.
  3. #3 Re: 2005 grand prix burning gas like crazy!
    Banned
    Apr 2011
    wv
    all i know is that cars running really rich will burn white. if theyre running unbelievably rich they can burn black. with modern EFI thats hardly possible.
    my 7.6 runs rich and burns white with intermitten black smog.
  4. #4 Re: 2005 grand prix burning gas like crazy!
    georgia
    here is an update guys, i cleaned the throttle body and added some fuel injector cleaner and it helped, i get more miles to the gallon now but its not completely back to normal, when i get sometime ill change out the wires and plugs. ill keep yall posted. thanks for all the advice..
  5. #5 Re: 2005 grand prix burning gas like crazy!
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    bad fuel sending unit?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  6. #6 Re: 2005 grand prix burning gas like crazy!
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    Wouldn't hurt to check your throttle body...I know that wouldn't be the main problem but cleaning it will help you gain MPGs back...
    By the way, like torq455 said, it is probably a fuel sending unit, a sensor or the pcm that failed...With a major problem like this one I would simply bring it back to the dealer and ask for a fix immediately!
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  1. 2005 grand prix oil check
    By 2005GrandPrix in forum General Tech Discussion
    Last Post: 02-05-2011, 01:24 AM
  2. crazy acting 07 grand prix
    By wide open 97 in forum General Tech Discussion
    Last Post: 02-03-2011, 09:27 PM
  3. My New 2005 Grand Prix
    By extreme in forum 04+ Specifics
    Last Post: 08-10-2009, 10:18 AM
