Thread: Misfire in Cylinder 6
Results 1 to 8 of 8
  1. #1 Misfire in Cylinder 6
    SE Level Member Porach's Avatar
    United States
    I have an 04 GTP and i have pace setter headers with 3 inch down pipe, 180 t stat, iridium plugs, and was running a 3.2 pulley when after racing once i hit second gear my engine start to misfire out of the cylinder 6. Im thinking my fuel injector went bad. Need some ideas before i buy a new injector.
  2. #2 Re: Misfire in Cylinder 6
    St. Louis
    Do you have all the supporting mods to run a 3.2? Does it miss constantly under normal driving conditions, or just sometimes?
    Hearing this started after a race makes me worry about the possibility of internal damage (ie- piston).
  3. #3 Re: Misfire in Cylinder 6
    United States
    this just happened today. i drove it home from were we raced and that was it. but ya i do have all supporting mods. i know it a fact that there is no internal damage. its just misfiring. i feel like its a fuel injector. so in the morning im going to switch the injector to see if the misfire moves. I no people that run small pulleys no problem with very little internal mods.
    No knock at all
  4. #4 Re: Misfire in Cylinder 6
    Mercer, Pa
    Check the plug yet? 04 gtp, is that a gen 5 or gen 3? 3.2 pulley is pretty small for gen 5 with just headers. Its pretty small for gen 3. What mods do you have? What thermostat?
  5. #5 Re: Misfire in Cylinder 6
    I agree, mods aren't really supporting for a 3.2. But hey..let's diagnose it.
    Being one cylinder it can be a plug, wire, coil. Those are where I'd start. If you haven't.. look at the wire. #6 is a long way from the coil and with headers..well burning a wire is possible.
  6. #6 Re: Misfire in Cylinder 6
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Check for spark. I would pull the fuel pump fuse, pull the #6 plug, grab it with some rubber tipped pliers, and ground the electrode out somewhere metal in the engine bay (coil bracket or something). Have a friend crank the car and make sure it sparks, and that it's not extremely weak either.
  7. #7 Re: Misfire in Cylinder 6
    United States
    it was the plug and the wire. i got that stuff fixed up. But i just posted something else i need help with! this is obnoxious. my s/c is knocking now
  8. #8 Re: Misfire in Cylinder 6
    That's most likely from a bad coupler...sure it isn't a bottom end knock from the 3.2" on your GenV with headers?
  1. Possible cylinder misfire
    By TopGunSalo in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-03-2010, 02:57 AM
  2. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. Cylinder 3 misfire...please help!!!
    By swifty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2010, 07:21 PM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
