Thread: Ac compressor replace how to do
Results 1 to 6 of 6
  1. #1 Ac compressor replace how to do
    Jun 2011
    vegas
    Need some advice on how to replace an a/c compressor. Is it a real simple take off and replace? Do i take it off the compressor from the bottom or top of the car , do i have to remove the fan to take off the compressor???
  2. #2 Re: Ac compressor replace how to do
    St. Louis
    I removed mine from the top. I did not remove the fan, or anything else for that matter. You will want to replace the orifice tube and probabaly the accumulator as well . Then you will need new o-rings for the compressor if it didn't come with any, and the accum. Some PAG oil to refill the new compressor and some in the accumulator. Then a vacuum pump to draw down the system to 30Hg. If it holds 30Hg of vac. for 1 hr. then the system is leak free and you can proceed to refill w/ the correct amount of R-134A (2.2lbs IIRC). Check the book to be sure as you don't want to overfill it.
    And no, gauges made for R12 refrigerant will NOT work w/ R134A. Different setup.
  3. #3 Re: Ac compressor replace how to do
    Enjoy the orifice tube.
  4. #4 Re: Ac compressor replace how to do
    St. Louis
    That's what she said
  5. #5 Re: Ac compressor replace how to do
    Never Never Land
    Meh I never messed with the orfice tube on mine.
    I took mine through the wheel well too. Guess i do it all different lol.
  6. #6 Re: Ac compressor replace how to do
    SE Level Member BCGTP's Avatar
    Apr 2011
    USA
    I'm getting ready to do this on mine. I was going to have the dealer do it but labor alone was $350 so screw that. How long did it take you guys? What brand did you go with on the compressor, or did you get a used one? How hard was the orifice tube? Is the accumulator a straight up remove and replace? Obviously new seals on everything, too.
  1. how much oil to put in compressor?
    By mcsddd in forum General Tech Discussion
    Last Post: 06-08-2011, 04:56 PM
  2. Compressor
    By InfidelRebel in forum General Tech Discussion
    Last Post: 08-13-2009, 01:41 AM
  3. AC Compressor
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-17-2009, 12:04 PM
