Thread: Wierd shifting at wot
Results 1 to 7 of 7
  1. #1 Wierd shifting at wot
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    Just got my 2000 grand prix gtp with 160kms(canada). I did the homeade intake and went for a drive. I let it warm up and then i floored it from a stop all the way to 160. But when I was in second gear, the rpms stopped at 5500 for a good second and then continued up to 6000ish and shifted normally. Any ideas on what could cause this, im really hoping my tranny isnt going already
  2. #2 Re: Wierd shifting at wot
    Do you have a modified pcm?
  3. #3 Re: Wierd shifting at wot
    May 2011
    Car is completely stock besides the homeade intake.
  4. #4 Re: Wierd shifting at wot
    Ok, in that case 6k is odd, because your shift point should be 5500-5700. Have you had this happen more than once?
  5. #5 Re: Wierd shifting at wot
    May 2011
    Ya it happens everytime, and I think the shift point is around 5700 with performance shift on. I just tried it with performance shift off and it shifted at 5500 without hesitation. Also I just had the engine light come on and it. is a o2 signal low bank 1 sensor 2, I have a leak in my exhaust so I think that may have caused that.
  6. #6 Re: Wierd shifting at wot
    Ahhhh fix the known issues. Then see if the other items fix themselves magically.
  7. #7 Re: Wierd shifting at wot
    May 2011
    Cleared the code, it still does it(I think this is the most I've hit 160 lol) but I noticed I'm not getting full boost, I'm missing 1 lego block.
  1. 2 to 3 tranny shifting & WOT shifting problems
    By josh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 08:52 PM
  2. Wierd Sound
    By TeeWX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 02:22 PM
  3. WIERD!!! has this happened to anyone else?
    By aron2409 in forum General Tech Discussion
    Last Post: 11-25-2009, 01:34 AM
  4. 97 gp shifting wierd
    By Thut420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-07-2009, 12:44 PM
  5. kr wierd issue
    By GTP4 in forum PCM Tuning
    Last Post: 02-18-2009, 08:20 AM
