Thread: Coolant in the exhaust manifold?
Results 1 to 17 of 17
  1. #1 Coolant in the exhaust manifold?
    jaydee
    Guest
    Hey guys, first time here. I posted this in a different forum, but this looks like it has a little more activity. My car is actually a Buick Riviera, hope that's ok
    I'm going to do this cliff-notes style, because it's easier to read. If you want more details, just ask and I'll provide.
    -My brother-in-law is a 3rd-party mechanic of 25+ years and has done all the major work on this car detailed here.
    -The car is 1996 Riviera with a 3800 SII SC L67 engine.
    -I bought the car in summer of 2007 w/135k miles.
    -No major engine work until we did the U/L IMG in June, 2010 @165k miles (bought aluminums from zzp: ZZ Performance)
    -Ran "fine" except high load, low RPM conditions (ran like this prior to IMG replacement)
    -Changed one coil pack in fall of 2010 and above was fixed
    -Seemed to lose some coolant but not alot since I've owned it, before and after the IMG change
    -I had never seen oil in coolant
    -Sold Rivi in January @175k miles to a family member, who drives a lots of very short trips, about 1-2 miles to work and back.
    -Ran the gas tank really low one time in March (upstate NY, very cold winters), and the next morning, the car started running VERY rough. Lots of white smoke
    -Tech 2 says cylinder #4 (I think) was misfiring. Only one cylinder was misfiring consistently
    -Changed spark plug on that one cylinder
    -Put dry gas and 5 gallons of fuel into fuel tank, ran a little better, but not much
    -Still lots of white smoke coming from exhaust
    -No trace of oil in coolant
    -I believe there was coolant in oil. Oil level was checked and was "overfilled" by a quart or two, suspected to be coolant
    -Head gasket suspected to be the problem
    -Life gets busy and the car sits for a couple months.
    -Tow the car to my bro-in-laws on Friday
    -Wanted to do compression check on all cylinders, but the starter seized today and it wouldn't turn over, so we didn't.
    -Today (06/26/2011), we stripped engine down to the block, found the 5 other spark plugs are really nasty
    -Coolant (hard to quantify, maybe a pint or a quart? No small amount...) found in the front exaust manifold, didn't see any in the back manifold
    -Both heads appear to be in good shape
    -No coolant in the cylinders themselves
    -Head gaskets are coming apart a little bit on the outter edge, but no big rips or tears around the cylinder portion
    -My brother-in-law wants me to buy another head & U/L MG set (Fel-Pro for $200), new headbolts ($20) and get the heads milled ($150).
    Your expert thoughts about any and all of this? How can coolant be in the oil and exhaust manifold but the heads/head gasket be ok? I need to do this for as cheap as possible on parts, labor isn't a big concern. Want to see pictures of anything?
    Thanks!
    jaydee
  2. #2 Re: Coolant in the exhaust manifold?
    St. Louis
    That sounds like a leaking LIM gasket to me. The head gaskets on these motors almost NEVER go. In fact, it would be the very last thing on my list. That's the only way I could see getting coolant in the oil and also getting it into the exhaust (by burning it).
  3. #3 Re: Coolant in the exhaust manifold?
    I'm with him.. ^^ even though he has Ford in his SN.
  4. #4 Re: Coolant in the exhaust manifold?
    St. Louis
    Hey, at least they circled the problem. With my Pontiacs all GM did is point to it
    jaydee, don't forget to get new head bolts when you reassemble as they are torque-to-yield bolts and not reuseable.
  5. #5 Re: Coolant in the exhaust manifold?
    jaydee
    Guest
    What do you mean by coolant getting into the exhaust "by burning it"? There was a pint or quart of liquid coolant in the exhaust manifold.
    Like I said, we already stripped it down to the block and the head gaskets looks "ok" around the cylinder portion. But the LIMG looks "ok" too. So I'm just confused about what actually happened. Regardless, when we put this thing back together, we'll need an all-new gasket set, no? Even if they look good, we can't reuse what's already been taken apart, correct?
  6. #6 Re: Coolant in the exhaust manifold?
    Quote Originally Posted by jaydee View Post
    if you pulled the heads, buy new head gaskets as well, dont re use them.
  7. #7 Re: Coolant in the exhaust manifold?
    Kansas
    Regardless if the LIM gasket looks "ok" replace it. The LIM gasket is one of the big thorns in the side of the GPs. Roughly it should be replaced at or before 100k w/ an aluminum gasket. Those last and hold up way better. And I also concur that your coolant is due to the LIM gasket leaking.
  8. #8 Re: Coolant in the exhaust manifold?
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Lim gasket went on my car before 60k
  9. #9 Re: Coolant in the exhaust manifold?
    jaydee
    Guest
    But if coolant was leaking through the LIMG, how did it get into the exhaust? Through the combustion chamber? We did not see any coolant in the cylinders themselves, just the exhaust manifold.
  10. #10 Re: Coolant in the exhaust manifold?
    a bad lim will suck the coolant into the intake passage and into the cylinder, and out the the exhaust valve and then the manifold, and you will have white smoke out the tail pipe.
    if theres coolant in the exhaust manifold thats the only way its going to get there.
    or a blown head gasket, but as stated above, thats unlikely unless the engine was really, really over heated.
  11. #11 Re: Coolant in the exhaust manifold?
    SE Level Member jmt455's Avatar
    SE Michigan
    I agree with all the the LIM comments, but if it sat outside and you had a really cold winter and the antifreeze mix wasn't up to snuff, it might have frozen and you might have a crack somewhere.
    I would verify that there are no cracks in the heads, block or any coolant passages in the manifold. Also make sure that the core (freeze) plugs are intact and not leaking. (just to be safe; not that these could be causing the current problem...)
    83 Bonneville wagon
    08 G8 Base
  12. #12 Re: Coolant in the exhaust manifold?
    jaydee
    Guest
    Thanks for all the constructive input guys, I appreciate it.
    Ok, so pretty sure it's the LIM then. But since the heads are already out, should I see about getting them re-milled, or just throw them back on with new head gaskets?
    Also, should I have any service done to the parts that are already out, clean them up with carb cleaner or something?
    Still having a tough time understanding how those aluminum IMG's could only last 6-7 months. If it was an installation problem, shouldn't it have acted up immediately?
  13. #13 Re: Coolant in the exhaust manifold?
    St. Louis
    As a rule of thumb I always clean everything that I take off to do a job, whether its a bracket or a head. Nothing goes back onto my engines dirty. Now I don't hot tank everything, but I do scrub them down w/ some brake cleaner or simple green to knock as much off as possible. This especially holds true for any areas that use o-rings to seal (like the coolant elbows on these cars).
    The only part I don't disturb is anything w/ burnt on oil (like inside the LIM or piston tops) as I don't want something coming loose later on and getting where it doesn't belong.
    Since both heads are already off it may be worth the extra $$ to have a machine shop check them for cracks and warpage. Not trying to make you spend extra $$ you may not have through so that's up to you.
    And I've seen install issues w/ gaskets creep up after some time has passed, its not totally uncommon. Don't forget your dab of RTV at all 4 corners where the LIM/heads/block all meet.
  14. #14 Re: Coolant in the exhaust manifold?
    St. Louis
    Oh, and before I forget. Before you reassemble the LIM dump at least a quart of cheap oil into the lifter valley to flush any coolant out of there, and then drain the oil before starting the car. Fill the car up w/ some cheap oil and use a cheap filter, then run it for a few minutes. Then re-drail that oil and change filter to a good one and refill w/ a good quality oil of your choice. Your rod and main bearings will thank you
  15. #15 Re: Coolant in the exhaust manifold?
    jaydee
    Guest
    Just talked to an engine shop about the heads to check for cracks/warpage. They suggested that whenever you take the heads off, you need to remill them, they'll never remain flat after you take them off. Which they charge $175 for. Is this necessarily true or are they just going after my money?
    Thanks!
  16. #16 Re: Coolant in the exhaust manifold?
    SE Michigan
    You might want to get another quote.
    I have done very few engine builds, but I've had the heads checked and the surfaces "cleaned up" on all of them.
    I'm sure the more experienced folks will have additional input on this one...
    83 Bonneville wagon
    08 G8 Base
  17. #17 Re: Coolant in the exhaust manifold?
    $75 a surface seems to be the rate around here.
    If you're having that done, i'd suggest a "rebuild".
    No point in doing half the job.
    But find a good machine shop first.
  1. Bright red exhaust manifold
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 04-17-2011, 02:16 PM
  2. 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    By Skillet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2011, 10:51 PM
  3. EGR Tube to exhaust manifold
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 02:43 PM
  4. exhaust manifold ?
    By 04GTPCOMPG in forum General Tech Discussion
    Last Post: 11-09-2009, 03:20 PM
  5. Exhaust Manifold bolts
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 06:05 PM
